Car brake line corroded
Chalky.
PostPosted: 11:30 - 20 May 2013    Post subject: Car brake line corroded Reply with quote
The brake line on one of my cars has corroded to the point where it sprays out brake fluid upon braking...
It the section of the pipe that runs along the rear beam. I would like it sorting as cheaply as possible as car will be sold on.
Can it be bodged? Gaffer tape may not cut the mustard.
Can I cut out the bad section and somehow bodge it that way? Or does it need a proper job doing.
Thanks
PostPosted: 11:40 - 20 May 2013    Post subject: Reply with quote
With brakes, always get it done properly. Especially if you are selling it after. Wouldn't be able to sell it with bodged brakes if it was me..
Chalky.
PostPosted: 11:45 - 20 May 2013    Post subject: Reply with quote
I'm a massive cunt though, don't forget Wink
Chalky.
No I'd like it done properly but cheaply - it's got to get through an MOT anyway Thumbs Up
lihp
PostPosted: 11:53 - 20 May 2013    Post subject: Reply with quote
Copper line?
Where are you based? I have plenty left over from when I had to redo all mine for MOT
J4mes
PostPosted: 11:56 - 20 May 2013    Post subject: Reply with quote
It wouldn't take a decent garage long to cut and flair some pipe to fit properly and safely. You'll need an old skool garage though, new ones will just try and sell you the whole brake line system I expect.
Chalky.
PostPosted: 12:29 - 20 May 2013    Post subject: Reply with quote
PhilDawson8270 wrote:
Copper line?
That was one of my thoughts Phil, I'm in Cheshire.
Does it go all the way through from front to back? Or a patching thing?
Was it a big job? Cheers
map
Mr Calendar
PostPosted: 13:15 - 20 May 2013    Post subject: Reply with quote
As said old school garage should be able to bend and fit copper pipe to fit. Or, like modern plumbing you could see if flexible pipe (like your bike brake lines) would work out cheaper for a quick fix (I'm not sure on the couplings required 'tween old and new though).
StormCrow
PostPosted: 14:03 - 20 May 2013    Post subject: Reply with quote
Any garage worth their salt will be able to cut out the old knackered section and replace the section that's fucked - most brake line kits come with joiners, they can therefore add a section into the middle.
Don't head for ATS etc, look for a small garage that's been going for years, "Phil down the road" type thing.
Like this:
https://i110.photobucket.com/albums/n113/f0xy_2006/--%20The%20MK1/IMG_1036.jpg
using these:
https://www.pentastarparts.com.au/store/images/products/large_4960_brake-line-joiner-kit.jpg
lihp
PostPosted: 19:38 - 20 May 2013    Post subject: Reply with quote
I'm in cheshire also. I have sent a PM
The last post was made 13 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 61.81 Kb
