Sintered / HH Sintered Brake pads
-Matt-
PostPosted: 12:27 - 20 May 2013    Post subject: Sintered / HH Sintered Brake pads Reply with quote
Hi all
I just wanted to check - if pads are described as 'sintered', would this be the same as HH sintered or is that the next level up and would specify the HH.
Is there any issues running none HH on the rear calliper with HH's on the front callipers if so.
Cheers Thumbs Up
bladerunner
PostPosted: 12:37 - 20 May 2013    Post subject: Reply with quote
You shouldn't use HH in the rear usually a lower grade would be preferable.
-Matt-
PostPosted: 12:44 - 20 May 2013    Post subject: Pads Reply with quote
Good point Embarassed got them serviced at a garage last time forgot that, thanks Laughing
Matt B
PostPosted: 12:46 - 20 May 2013    Post subject: Reply with quote
Sintering is the process of fusing together certain particles using heat and pressure, it's how pads are made.
HH pads (made by sintering) have a higher friction rating and are designed to perform at higher temperatures than other compounds.
Just put cheap pads in the rear.
-Matt-
PostPosted: 14:15 - 20 May 2013    Post subject: Reply with quote
Ah so sintered arent nescessarily HH was wondering why they all seemed to be sintered rear before. Thanks for explaining
Fizzer Thou
PostPosted: 14:43 - 20 May 2013    Post subject: Reply with quote
I use GG rated sintered pads on the rear discs for the R1 and Exup1000,but HH rated pads front and rear of the KTM enduro as they need to cut through any mud or water on the disc surface.That and I need to lock up the back brake easily on the enduro as it helps to get around corners quicker Wink
Also be aware that HH rated pads do tend to accelerate disc wear
Always have a 'Plan B'
-Matt-
PostPosted: 14:53 - 20 May 2013    Post subject: Reply with quote
Thanks mate, just picked up a pair of gg's for 9.99 online Smile
The last post was made 13 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 51.41 Kb
