| Fowlersrs |
 Fowlersrs World Chat Champion
 Posted: 20:18 - 20 May 2013 Post subject: Suspension Questions (understanding) |
Right I feel quite noobish in the fact ive had bikes for a while but never really considered how much adjustability there is with motorcycle suspension with just using tools compared to what there is with cars, its something ive never considered looking at, prob a bit scared too if im completely honest!!
But in order to rediscover my little speed four ive decided to start having a play, im bless with having all 3 adjustments front and rear so im well and truly jumping in at the deep end. Im gonna have a whole load of questions on the way and im hoping a few peeps can help explain exactly what effect the things im adjusting have on the bike and how it rides.. thats whats important for me, understanding why im doing these things..
so ive had a good read of articles supplied to me about the 3 settings, preload, damp compression & damp rebound. the way I see it is that the most important thing to setup first is the PRELOAD.
so here is my first question;
setting the preload in general is based on rider weight correct? In particular on the rear it is necessary to do this because your weight is directly over the rear shock?
Now Performance bike mag did an article on my speedy four settings a while ago and based on a rider weight of 170 pounds, incidently bang on what I weigh they have come up with the following settings for pre load;
PB Road settings:
rear-
preload: 44mm threads showing above lock ring
rebound: 0.75 turns out from full in
compression: 0.5 turns out from full in
front-
preload: 3 lines showing
rebound: 0.5 turns out from full in
tire pressure: 36 ft, 42 rr
Now for a moment its rear pre load I want to focus on as this is the only thing im struggling to adjust because the frickin nuts are so tight? As standard the speed for has 37mm thread showing above the rings, now theyre suggesting adjusting this down to achieve 44mm above the lock rings..
my question is what does this actually do to the bike, the way it looks is im winding the lock nuts down onto the spring and putting the spring under more tension? so this could be why its so hard to budge? Does this then lower the bike, if u weigh less u can have the bike lower to the ground? and does this then make the back end more stiff as a result? |
| MarJay |
 MarJay But it's British!
 Posted: 21:35 - 20 May 2013 Post subject: |
| Fowlersrs wrote: |
my question is what does this actually do to the bike, |
Increased spring preload will increase the ride height slightly, and will mean that the static sag is less. The rider sag should be spot on if they used a rider of your weight. I usually don't like mag 'setup guides' like that which tell you individual settings because they rarely tell you the weight of the rider they used. In this case they do, and you weigh the same which is good.
| Fowlersrs wrote: |
the way it looks is im winding the lock nuts down onto the spring and putting the spring under more tension? |
Yes.
| Fowlersrs wrote: | so this could be why its so hard to budge? | Yes, but there are two locking rings. You need to undo the top one, then tighten the bottom one, then tighten the top one so it locks against the bottom one.
| Fowlersrs wrote: |
Does this then lower the bike, if u weigh less u can have the bike lower to the ground? | Yes.
| Fowlersrs wrote: | and does this then make the back end more stiff as a result? | More stiff... not exactly. It means the back end will take more weight before the spring compresses, hence you're setting static/rider sag. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| Fowlersrs |
| mentalboy |
 mentalboy World Chat Champion
| Fowlersrs |
 Posted: 07:11 - 21 May 2013 Post subject: |
Thanks I have actually had a good read over it and I keep going back too it for reference as it is a good article, my questions above tho still remain un-answered. |
| weasley |
 weasley World Chat Champion
| Fowlersrs |
| Fizzer Thou |
 Posted: 09:12 - 21 May 2013 Post subject: |
Making the spring less in height increases preload on the spring.This increases the rear ride height and decreases rider SAG.
The damper clickers do not affect sag.Get the SAG correct first then adjust the clickers 3 steps at a time so that you can feel a change.One click here or there you will not notice.Keep a note of your standard settings so that if you get into a muddle you can always resort back to where your last preferred settings were.
I found that when I bought my R1 the first time out on it the ride was all over the place on standard settings - which was probably the reason why my friend sold it to me.I then adjusted it to some recommended settings and it was far better.But after I changed the shock and fork springs to Ohlins items I had to go back and set it up again,starting with the SAG.But it does make a big differance to the quality of the ride - much more fun  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| MarJay |
| Fowlersrs |
| MarJay |
| Fowlersrs |
The last post was made 13 years, 143 days ago. Instead of replying here, would creating a new thread be more useful? |
