Suspension Questions (understanding)
Fowlersrs
PostPosted: 20:18 - 20 May 2013    Post subject: Suspension Questions (understanding) Reply with quote
Right I feel quite noobish in the fact ive had bikes for a while but never really considered how much adjustability there is with motorcycle suspension with just using tools compared to what there is with cars, its something ive never considered looking at, prob a bit scared too if im completely honest!!
But in order to rediscover my little speed four ive decided to start having a play, im bless with having all 3 adjustments front and rear so im well and truly jumping in at the deep end. Im gonna have a whole load of questions on the way and im hoping a few peeps can help explain exactly what effect the things im adjusting have on the bike and how it rides.. thats whats important for me, understanding why im doing these things..
so ive had a good read of articles supplied to me about the 3 settings, preload, damp compression & damp rebound. the way I see it is that the most important thing to setup first is the PRELOAD.
so here is my first question;
setting the preload in general is based on rider weight correct? In particular on the rear it is necessary to do this because your weight is directly over the rear shock?
Now Performance bike mag did an article on my speedy four settings a while ago and based on a rider weight of 170 pounds, incidently bang on what I weigh they have come up with the following settings for pre load;
PB Road settings:
rear-
preload: 44mm threads showing above lock ring
rebound: 0.75 turns out from full in
compression: 0.5 turns out from full in
front-
preload: 3 lines showing
rebound: 0.5 turns out from full in
tire pressure: 36 ft, 42 rr
Now for a moment its rear pre load I want to focus on as this is the only thing im struggling to adjust because the frickin nuts are so tight? As standard the speed for has 37mm thread showing above the rings, now theyre suggesting adjusting this down to achieve 44mm above the lock rings..
my question is what does this actually do to the bike, the way it looks is im winding the lock nuts down onto the spring and putting the spring under more tension? so this could be why its so hard to budge? Does this then lower the bike, if u weigh less u can have the bike lower to the ground? and does this then make the back end more stiff as a result?
PostPosted: 21:35 - 20 May 2013    Post subject: Reply with quote
Increased spring preload will increase the ride height slightly, and will mean that the static sag is less. The rider sag should be spot on if they used a rider of your weight. I usually don't like mag 'setup guides' like that which tell you individual settings because they rarely tell you the weight of the rider they used. In this case they do, and you weigh the same which is good.
Yes.
Yes, but there are two locking rings. You need to undo the top one, then tighten the bottom one, then tighten the top one so it locks against the bottom one.
Yes.
More stiff... not exactly. It means the back end will take more weight before the spring compresses, hence you're setting static/rider sag.
Fowlersrs
PostPosted: 22:19 - 20 May 2013    Post subject: Reply with quote
Right so let me get this straight, winding the locking nuts down and compressing the springs (hence showing more thread above) is defined as increasing the pre load correct?
Does this have the affect of increasing the ride height or lowering it?
To me it sounds like it would lower the bike and increase static sag as with more compression on the spring the bike will sag easier?
What I'm trying to work out in my head is why are the winding down to achieve more/less preload from the standard setting of 37mm above the lock rings to 47mm, what are they achieving by doing this to the bike?!
mentalboy
PostPosted: 22:51 - 20 May 2013    Post subject: Reply with quote
I found this an interesting read.
https://www.gostar-racing.com/club/motorcycle_suspension_set-up.htm
Make mine a Corona.
Fowlersrs
PostPosted: 07:11 - 21 May 2013    Post subject: Reply with quote
mentalboy wrote:
Thanks I have actually had a good read over it and I keep going back too it for reference as it is a good article, my questions above tho still remain un-answered.
weasley
PostPosted: 07:36 - 21 May 2013    Post subject: Reply with quote
Just to get over a common myth. Increasing preload does NOT affect spring tension. All it does is raise the height at which the spring settles to its loaded rest point. It is to alter which part of the shock/fork's travel is used (to prevent bottoming out but allow as much stroke to be used as possible).
You can not affect a spring's tension by twiddling a nut.
Fowlersrs
PostPosted: 07:42 - 21 May 2013    Post subject: Reply with quote
Thanks for that. Hence the compression and rebound adjustments right? Smile
Can I ask, is winding the nuts down increasing or decreasing pre load. That's what I'm stuck with
Fizzer Thou
PostPosted: 09:12 - 21 May 2013    Post subject: Reply with quote
Making the spring less in height increases preload on the spring.This increases the rear ride height and decreases rider SAG.
The damper clickers do not affect sag.Get the SAG correct first then adjust the clickers 3 steps at a time so that you can feel a change.One click here or there you will not notice.Keep a note of your standard settings so that if you get into a muddle you can always resort back to where your last preferred settings were.
I found that when I bought my R1 the first time out on it the ride was all over the place on standard settings - which was probably the reason why my friend sold it to me.I then adjusted it to some recommended settings and it was far better.But after I changed the shock and fork springs to Ohlins items I had to go back and set it up again,starting with the SAG.But it does make a big differance to the quality of the ride - much more fun Thumbs Up Very Happy Thumbs Up
Always have a 'Plan B'
PostPosted: 11:36 - 21 May 2013    Post subject: Reply with quote
Winding them down increases preload. That is, turning them clockwise, tightening them. But as I said, you need to undo the locking ring first.
Fowlersrs
PostPosted: 11:43 - 21 May 2013    Post subject: Reply with quote
Yeah there's 2 rings. Top one locks the bottom one in position right so if I slacken the top one I should be able to wind the bottom one down then right? Then once I'm happy just bring the top locking one down to meet it?!
PostPosted: 12:52 - 21 May 2013    Post subject: Reply with quote
Mate. You've answered your own questions in EVERY instance so far... Maybe have a little confidence in your own ability to fathom the answer to a problem, and you wouldn't need to ask so many questions!
By the way, yes to this one too.
Fowlersrs
PostPosted: 13:50 - 21 May 2013    Post subject: Reply with quote
Embarassed ok no worries Thumbs Up
The last post was made 13 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 80.34 Kb
