honda cm 125 loosing power
dogsey
PostPosted: 15:55 - 23 May 2013    Post subject: honda cm 125 loosing power Reply with quote
hi i wonder if anyone can help my cm is loosing power at full throttle when i am riding it,it revs fine when in neutral cleaned the carb,and air filter if i ride it around town its ok but when i went on the dual carrigeway it wouldn't go over 40mph it seemed like when you are running out of petrol and need to switch to reserve that's the only way i can explain it thanks all Sad
Az
PostPosted: 16:05 - 23 May 2013    Post subject: Reply with quote
Would of said a clogged up air filter but since you've checked that, next thing i'd say would be the fuel pump, it may need replacing.
Edit: IGNORE THE ABOVE, you're bike doesn't have a fuel pump. Sorry for giving wrong advice, hope u didn't waste time looking for a fuel pump for ur bike.
dogsey
PostPosted: 16:07 - 23 May 2013    Post subject: Reply with quote
i dont think it has a fuel pump
Az
PostPosted: 16:21 - 23 May 2013    Post subject: Reply with quote
i feel pretty stupid now aha, only FI bikes have fuel pumps don't they.
My bad Confused
BillyJ
PostPosted: 16:46 - 23 May 2013    Post subject: Reply with quote
It's a small bike, at those speeds your probably getting an equal amount of fuel into the carb as the carb is using and therefore hit a peak in power as you cant get fuel in faster.
Try making the breather hole bigger so you get more fuel flow.
EDIT: When was the last time you went over 40?
Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser"
dogsey
PostPosted: 22:35 - 23 May 2013    Post subject: Reply with quote
hi i have been getting around 55-60 mph up until yesterday when the throttle is about three quarters turned i can get up to speed in the end but the last quarter turn the engine goes sluggish then if i turn the throttle back to three quarters the engine starts picking up again it started playing up when i put my fuel on reserve so i dunno if that had anything to do with it
The last post was made 13 years, 76 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 47.81 Kb
