problems starting/running
Andyk
PostPosted: 09:02 - 24 May 2013    Post subject: problems starting/running Reply with quote
when i try to start my bike i need to have the choke fully on and turn the throttle several times untill it catches. after this i then have to ride for around 5-10mins with the choke on about half to warm the bike up otherwise it stalls when coming to a stop
what could be causing this?
Cheers
Andy
mudcow007
PostPosted: 09:09 - 24 May 2013    Post subject: Reply with quote
is the bike just not cold?
Andyk
PostPosted: 09:11 - 24 May 2013    Post subject: Reply with quote
i thought this but needing this much choke plus throttle to start? makes me a bit worried about what it could be like in winter Shocked
mudcow007
PostPosted: 09:36 - 24 May 2013    Post subject: Reply with quote
just to make you feel a bit worse-er
i started my ye olde CG this morning, at the point i normally turn the choke off i reach down i realized i had left the choke off, but it had still started anyways
woop woop
stickybackbob
PostPosted: 12:03 - 24 May 2013    Post subject: Reply with quote
Sounds like the OP's bike is running lean or has a vacuum leak. Check the condition of the spark plug. It should be a nice tan colour.
As for Mudcow's bike, the CG may be running a little rich but with the slightly warmer weather, then choke isn't always needed Smile
P.
PostPosted: 12:15 - 24 May 2013    Post subject: Reply with quote
Put choke on, press starter. Ignore the the throttle.
Tickle the throttle, no need to open it all the way, just 1/8th, if that.
Start it on choke, ride gently for a mile and knock the choke off. Your idle when warm depending on bike should be a bit above 1000rpm. Most bikes I've ridden are between 1200rpm and 14rpm when warm.
Ilyin
PostPosted: 12:33 - 24 May 2013    Post subject: Reply with quote
This:
Opening your throttle when your chokes on defeats the point of it.
The last post was made 12 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 51.1 Kb
