Call me a div but....
freestyler_onli
PostPosted: 13:53 - 30 Nov 2004    Post subject: Call me a div but.... Reply with quote
Ok i got a new helmet today-tried it on and it fits like a glove (which i got as well). But when i shut the visor-it steams up within 2 secs and reduces visibility by 30%. Any tips-ie- stuff to rub on it or summin or what??? Embarassed
stryker
PostPosted: 13:59 - 30 Nov 2004    Post subject: Reply with quote
Most have vents now. Check the helmet vents are open (usually on the outside of the helmet).
There are a million and one anti fog inserts and sprays available from all good bike shops. I'm sure someone will drop by and recommend one.
Incidently, I don't need anything with my takachi helmet as I keep the vents open.
Now what?
freestyler_onli
PostPosted: 14:03 - 30 Nov 2004    Post subject: Reply with quote
Yeah ta. I got a 'Nitro' or some such name helmet. I did open all the vents after finding them all which helped a bit-but as you said i'll enquire about these inserts/sprays etc... ta.
8316
PostPosted: 14:09 - 30 Nov 2004    Post subject: Reply with quote
why dont you use fogcity visor inserts.
for a tenner they are well worth it. fantastic value Laughing
Now own a Fireblade!! Speed Limits? Bah!
freestyler_onli
PostPosted: 14:12 - 30 Nov 2004    Post subject: Reply with quote
Right ta for that-im making notes. Smile
mchaggis
PostPosted: 14:48 - 30 Nov 2004    Post subject: Reply with quote
Fog City are the way to go in my experience. It works absolute wonders. Mine cost me £15 fitted to the helmet I got in August from HG.
I must not be a troll...
Mmmm, Guinness
freestyler_onli
PostPosted: 14:50 - 30 Nov 2004    Post subject: Reply with quote
Lovely-these seem to be popular so i'll give them a go-at that price it doesn't really matter if they don't sort it out 100%.
ts50x0
PostPosted: 14:55 - 30 Nov 2004    Post subject: Reply with quote
i had a foogy mask but unfortunatly i found it really uncomfortable. sad because they work amazingly well, i just couldnt concentrate properly with it and it felt so awkward!
freestyler_onli
PostPosted: 14:57 - 30 Nov 2004    Post subject: Reply with quote
Hmmm. I guess the best thing to do is trial and error. That way i can see if it works and then how it feels. Confused
8316
PostPosted: 15:03 - 30 Nov 2004    Post subject: Reply with quote
i've used foggy masks as well, as walker used them. they do work perfectly, but you feel slightly restricted-and it smells too! Laughing
freestyler_onli
PostPosted: 15:04 - 30 Nov 2004    Post subject: Reply with quote
Well if you get hot and sweaty-it'll only add to the smell lol.
dainesefreak
PostPosted: 15:19 - 30 Nov 2004    Post subject: Reply with quote
Fog City. Thumbs Up Works really well, better than the spray I've used, but . . . .
Motrax Fog Free spray. Thumbs Up
The spray has lasted me ages, a couple of squirts on the inside of the visor and a lint free cloth. It does sort of need reapplying every night, but as I said the little can has lasted ages and only costs about £4.
stryker
PostPosted: 16:03 - 30 Nov 2004    Post subject: Reply with quote
A necktube thingy that covers your mouth then breathing through your mouth may help, that stopped what little fogging I ever had.
Now what?
sainttm
PostPosted: 16:11 - 30 Nov 2004    Post subject: Reply with quote
its probably a dumm suggestion but it worked for me,
why dont you leave a couple inch gap, it stops the rain/wind from getting to you and stops the steam (downside is there a small draft and your face goes numb lol).
I have glasses and fount it a right pain till my instructor told me about it and it works. Although when you pull up at juinctions and not moving the wind cant get to the glasses and they steam up but the visor is still good. If you beath down aswell it prevents them from steaming up.
Hope this helps,
Shane
freestyler_onli
PostPosted: 16:43 - 30 Nov 2004    Post subject: Reply with quote
Yeah good advice here guys- i did buy like a wind balaclava thing (Look like a Navy SEAL) and i tried them both on and it helped a bit-as you said- maybe a few mm's of leaving the visor open might help-ill try and let u know!
sychosis
PostPosted: 16:52 - 30 Nov 2004    Post subject: Reply with quote
I use a foggy mask and it works great, when it starts to smell I just put it through the washer.
Bikes owned: Aprilia RS 125 GP1 2003 (Now sold), Suzuki GSX-r600 1997 (streetfightered), https://www.bikepics.com/members/sychosis/
psy?cho?sis (si-ko-sis),n. pl. psy?cho?ses (-sez) ,A severe mental disorder, with or without organic damage, characterized by derangement of personality and loss of contact with reality and causing deterioration of normal social functioning.
freestyler_onli
PostPosted: 16:59 - 30 Nov 2004    Post subject: Reply with quote
Gor i tell you what-the balaclava thing i got dont hal hurt the top of me head-i might get one of those sorta scarf things that you pull over from the neck. Shocked
Barker-CBR 600
PostPosted: 23:31 - 30 Nov 2004    Post subject: Reply with quote
All the products are good.
But remember that once you get going things generally steam up less unless its freezing outside...
Wearing balaclava will trap alot more heat in (Ride says 70%) but it'll also raise the temperature of the ait under your visor.. hence leading to more steaming.
I can get away 7am 30 minutes journeys if i dont wear a neck warmer since its as cold inside as it is outside , but with one on i use Anti-Fog spray. Most are good, but rememebr to take it with you or coming home will be misty! (only lasts an hour or two effectivly a coating)
Previous - Gilera DNA50 / XVS125 Dragstar/Honda CBR 600F/GSF 650 Bandit
Current - 2013 Suzuki VZ800 Intruder
'Is this a rhetorical question?'
Hex
Party Boy
PostPosted: 23:36 - 30 Nov 2004    Post subject: Reply with quote
Washing up liquid, thats what I use and damn its cheep compared to some of the lotions and potions on the market.
Granted it needs reapplying but its a good excuse to clean the visor!
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
JonB
Afraid of Mileage
PostPosted: 23:53 - 30 Nov 2004    Post subject: Reply with quote
Breath out through your nose, air gets directed downwards and out of the helmet, works for me! Very Happy Thumbs Up
freestyler_onli
PostPosted: 00:23 - 01 Dec 2004    Post subject: Reply with quote
AHA!!! I didn't think of that- i tried it and that's better. It which case- i'll get a few bits and bobs and just make sure i got at least one of them on me. Smile
Barker-CBR 600
PostPosted: 23:16 - 01 Dec 2004    Post subject: Reply with quote
THE ULTIMATE NON STEAMING UP HELMET!
I GUARANTEE YOU THAT THIS HELMET WILL NOT STEAM UP NO MATTER WHAT CONDITIONS YOU PUT IT THROUGH! ITS AMAZING!
https://www.skydivestore.com/gear/hh6_lg.gif
Slap me now...
freestyler_onli
PostPosted: 01:44 - 02 Dec 2004    Post subject: Reply with quote
LOL!
Yes i guaruntee that one won't. I got them strip things which you stick in the helmet. I actually got a 2nd helmet-and i can fit the balaclava under this with no more sores. Lovely. Cool
freestyler_onli
PostPosted: 10:48 - 02 Dec 2004    Post subject: Reply with quote
Right-i fitted the 'Fog City' thing and it works perfectly- ta guys! Very Happy Only problem being that i didn't realise it was a 'smoke' coloured one till i got it home-which means i'll have to get a second helmet with a clear one in-never mind-its not that expensive. Very Happy
jay12329
Dr. Evil
PostPosted: 18:48 - 02 Dec 2004    Post subject: Reply with quote
I had a fog city hyper optic in my old lid. was almost clear in the dark and changed to a dark blue in bright sunlight, it was realy good. It might be work considering for you other lid as it means you can use it when going out in bright sun when you know you will coming home in the dark.
HTH
J
The last post was made 21 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 123.57 Kb
