YBR 125 (2006) Wiring Question?
tterminus
PostPosted: 14:48 - 19 May 2013    Post subject: YBR 125 (2006) Wiring Question? Reply with quote
Hi all, new to this two wheels and an engine malarky so decided to buy a stolen/recovered YBR 125 and get it back on the road then do my CBT but have to admit the wiring situation has me currently stumped...
Under the side panel there are two wires and a 9 pin plug hanging loose. I believe one of the wires (red) should be connected to a spade connector which itself plugs into a fuse holder coming off the battery's positive terminal.
The other loose wire (brown) is coming from the front of the bike but cannot spot any corresponding point it might have come from, any suggestions?
Suppose I really need to find my multi-meter and try and trace it through.
Also there are two cables going to a 9 pin (3x3) plug which is hanging loose. Any ideas what this should have been plugged into? Sadly there is nothing obvious to my eyes.
Apologies for my neophyte struggles but thought buying and repairing a non-runner as my first motorbike would be both fun and a good introduction to what makes them tick!
Cheers.
scotthx1
PostPosted: 16:12 - 23 May 2013    Post subject: Reply with quote
have you got a picture of your wiring i could check mine and see where everything goes ,
Az
PostPosted: 20:56 - 24 May 2013    Post subject: Reply with quote
I think the 9 pin plug connects to the CDI, not 100% sure.
Efes123
PostPosted: 05:54 - 25 May 2013    Post subject: Reply with quote
The red one coming from the fuse normally goes to the starter solenoid. That's your main live feed.
The brown one could be almost anything, as could the 9 pin (lights, bar controls, ignition...). I'd connect up the red one, and see what doesn't work. And yes, you really do need a multimeter.
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
J.M.
PostPosted: 06:57 - 25 May 2013    Post subject: Reply with quote
https://members.chello.cz/user/ybr/schema.png
But I don't see any 9-pin connectors.
2004 R1 & 2018 XSR900
Efes123
PostPosted: 10:00 - 25 May 2013    Post subject: Reply with quote
The ignition is normally a 9 pin, doesn't always mean there are 9 wires though Very Happy
tterminus
PostPosted: 10:13 - 27 May 2013    Post subject: Reply with quote
Thanks for the advice/replies.
Here's a photo of the electrics in question:
https://www.terminalterminus.co.uk/Photos/BasketElectrics.jpg
Not the clearest photo but hopefully you can spot the loose red (which I believe should be attached to a spade connector which is then plugged into the point just below the blue fuse).
The loose brown (top, middle) goes to the front of the bike so either I need to find the damned multimeter (God, my shed is a mess!) or as Efes123 suggests connect what I can up and see what doesn't work.
The white 9 pin plug (bottom right of photo, 8 pins actually connected) is still bit of a mystery. As it goes to the rear lights could it possibly be for some form of relay unit?
Also wary of connecting my aftermarket ebay ignition after reading some comments from people who have had to rewire after blowing their fuses (another reason to find the multimeter).
Cheers all.
Efes123
PostPosted: 14:28 - 27 May 2013    Post subject: Reply with quote
I'd pop the red one into the blue connector. Tose are supposed to connect two wires into one, so if there's only one running through it, then it probably goes in there. Is there a slight cut in the plastic?
The last post was made 12 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 57.82 Kb
