| mafia9966300 |
 mafia9966300 Two Stroke Sniffer
 Posted: 15:37 - 26 May 2013 Post subject: Rear Brake Pads don't fit ? ? (Its not the piston)[CBR 600fs |
| yen_powell |
 yen_powell World Chat Champion
| mafia9966300 |
| yen_powell |
| mafia9966300 |
| Islander |
 Islander World Chat Champion
| yen_powell |
 Posted: 06:28 - 27 May 2013 Post subject: |
https://i.imgur.com/cD5RGBy.jpg
In this picture, between the piston and the brake pad you can see a small circular rubber bellows.
Now you have undone the single sliding bolt and pivoted the calliper upwards, the whole thing is sitting on a sliding pin which that rubber bellows is protecting from the weather.
If you pull the calliper away from the wheel it should (if it's not seized) slide straight off the pin which is part of the bracket. The rubber will stay with the calliper leaving the pin on the bracket which you can clean up and lube before popping the calliper back on (check inside the calliper to make sure there are no nasties inside the hole). ____________________ Blackmail is a nasty word........but not as nasty as phlegm!
XT1200Z and a DR350 in bits |
| andym |
 andym World Chat Champion
| whitedevil |
 whitedevil World Chat Champion
 Posted: 10:46 - 27 May 2013 Post subject: |
This should help
https://i.imgur.com/wdij1HH.png ____________________ GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R |
| mafia9966300 |
 Posted: 13:16 - 27 May 2013 Post subject: |
Thanks for all the input.
I opened it up again today and noted that front number 13 bolt was too tight, it had squashed number 14 rubber bit (bellows?). I loosened it and that seemed to have solved the problem. For my understanding this should not be so tight.
See image below, red circle is for the squashed rubber bit after I loosened it. Green circle is the number 13 bolt i loosened.
https://i.imgur.com/dFfzuRC.jpg
Is that ok ? ____________________ I WANT ALL YOUR KARMAz! |
| Islander |
| Aff |
 Aff World Chat Champion
The last post was made 12 years, 218 days ago. Instead of replying here, would creating a new thread be more useful? |
