Rear Brake Pads don't fit ? ? (Its not the piston)[CBR 600fs
mafia9966300
PostPosted: 15:37 - 26 May 2013    Post subject: Rear Brake Pads don't fit ? ? (Its not the piston)[CBR 600fs Reply with quote
Hey all,
My new brake pads don't fit wtf ?
Bought them from here:
https://www.ebay.com/itm/260931541782?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
https://i.imgur.com/cD5RGBy.jpg
https://i.imgur.com/7mNGsNL.jpg
Can anyone help me out ?
Cheeers.
I WANT ALL YOUR KARMAz!
yen_powell
PostPosted: 15:53 - 26 May 2013    Post subject: Reply with quote
Push the calliper towards the wheel, it's sitting on a slider.
XT1200Z and a DR350 in bits
mafia9966300
PostPosted: 16:33 - 26 May 2013    Post subject: Reply with quote
I tried pushing calliper but it would not move ? Should I push harder or something ?
yen_powell
PostPosted: 17:15 - 26 May 2013    Post subject: Reply with quote
Does it move back and forth at all? If not pull it off the slider, clean and lube the slider with some copper grease. You've got the same calliper as my Africa Twin, you have to keep on top of the maintenance or the weather kills them.
mafia9966300
PostPosted: 21:28 - 26 May 2013    Post subject: Reply with quote
Thanks for the info, sorry I'm a noob. What is the slider ?
Islander
PostPosted: 21:59 - 26 May 2013    Post subject: Reply with quote
The caliper 'floats' on a couple of steel pins and corrosion/road crap can cause it to sieze rather than move freely. It'll have to be removed, freed, cleaned up and greased. Use a general lithium type grease rather than copper grease which is intended for use as an anti-sieze compound rather than a lubricant.
yen_powell
PostPosted: 06:28 - 27 May 2013    Post subject: Reply with quote
In this picture, between the piston and the brake pad you can see a small circular rubber bellows.
Now you have undone the single sliding bolt and pivoted the calliper upwards, the whole thing is sitting on a sliding pin which that rubber bellows is protecting from the weather.
If you pull the calliper away from the wheel it should (if it's not seized) slide straight off the pin which is part of the bracket. The rubber will stay with the calliper leaving the pin on the bracket which you can clean up and lube before popping the calliper back on (check inside the calliper to make sure there are no nasties inside the hole).
andym
PostPosted: 09:46 - 27 May 2013    Post subject: Reply with quote
From the picture it looks like the end of the bellow has popped out which would mean there is a long way for the calliper to slide back.
Depending on how long the bellow has been disconnected there could be some crud in there stopping it from moving properly.
Other easy option would be to sand down the pad (that's a joke by the way)
whitedevil
PostPosted: 10:46 - 27 May 2013    Post subject: Reply with quote
This should help
https://i.imgur.com/wdij1HH.png
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
mafia9966300
PostPosted: 13:16 - 27 May 2013    Post subject: Reply with quote
Thanks for all the input.
I opened it up again today and noted that front number 13 bolt was too tight, it had squashed number 14 rubber bit (bellows?). I loosened it and that seemed to have solved the problem. For my understanding this should not be so tight.
See image below, red circle is for the squashed rubber bit after I loosened it. Green circle is the number 13 bolt i loosened.
https://i.imgur.com/dFfzuRC.jpg
Is that ok ?
Islander
PostPosted: 20:10 - 27 May 2013    Post subject: Reply with quote
No. From memory the torque on that bolt should be around 27N m. The caliper isn't sliding freely on the pins because of corrosion or road crap. Loosening a fitting isn't the answer.
Aff
PostPosted: 20:28 - 27 May 2013    Post subject: Reply with quote
^ Yup 27Nm
https://i1135.photobucket.com/albums/m637/Biles/27-05-201321-26-30_zps332a593d.png
Whip the pin out and clean all the road crap/corrosion off, put a bit of silicone paste on and reinstall.
Electric Bike Project
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 73.06 Kb
