Quick Mineral 10w/30 or 10w/40 labeled as Diesel
wots
PostPosted: 12:25 - 27 May 2013    Post subject: Quick Mineral 10w/30 or 10w/40 labeled as Diesel Reply with quote
Cocked up a bit and all oil out. Have either Halfords Diesel 10w/40 or cheap mineral 10w/30 and no opportunity to get something else.
I change every 1K currently.
I suspect 10w/40 Diesel will be nearest to spec.
Advice please. All oil is currently out. Including filter.
Thanks
neatbik
PostPosted: 15:19 - 27 May 2013    Post subject: Reply with quote
For the CBF right?
I would use the 10-30 to be honest, then sort out some decent stuff for it when you get a chance.
PostPosted: 15:41 - 27 May 2013    Post subject: Reply with quote
I'd use either. At this time of year the viscosity difference is going to be negligeable.
The diesel stuff will have a higher level of detergent in than standard oil. Can't see why this would be a problem.
wots
PostPosted: 15:47 - 27 May 2013    Post subject: Reply with quote
It was the ER6. I plumped for the diesel after a google, which suggested as above, there wasn't a lot in it. Just more detergents. I'll change it again in 1k 'ish and buy some proper stuff. Castrol 4T seems as good as anything.
I dropped all the oil and changed the filter so I know it's all good. I wasn't expecting it to be quite as black for only about 1K done on that oil. We'll see how it goes on this.
I don't mind changing the oil more regular than necessary, it's the cheapest/easiest way of keeping the engine in good order for not a lot.
P.
PostPosted: 17:46 - 27 May 2013    Post subject: Reply with quote
I've used petrol and diesel ones, doesn't really seem to do much different. Better than no oil.
Mark65
PostPosted: 13:02 - 28 May 2013    Post subject: Reply with quote
Ive used diesel oil in the past in my YBR, it was cheap and SG rated, worked fine, CarPlan I think.
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 48.11 Kb
