| davidzweig |
 davidzweig Borekit Bruiser
 Posted: 19:02 - 23 May 2013 Post subject: 150cc big bore kit for CG125 on eBay |
I'm planning to travel the back-roads of Eastern Europe in the summer on my '94 CG125. My girlfriend wants to come, so a little extra power wouldn't hurt for going up hills. Size wise the bike is alright for the two of us, we weigh about 135kg together, and would pack light. If we could hold a comfortable 50mph, that would be alright. The bike has a front disc brake.
I have a full license and my last bike was an XT600, so not riding a CG because I'm on L plates or something.
I found this on eBay:
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=151039342017&ssPageName=ADME:X:RTQ:GB:1123
Title reads 'Motorcycle Big Bore Barrel & Piston Kit For Honda CG125 1978-2008 NOT ES Models'
From reading online, I thought the maximum capacity possible on the CG125 without machining the crankcase is 140cc ish? Seller confirms it's for a CG125, not a Chinese copy. Could it be?
150cc is a 20% boost in cc's, so I guess that would mean an almost 20% extra torque, given that some volumetric efficiency would be lost. Would the bottom end cope alright, or would it significantly shorten the life of the bearings etc.? I guess the bottom end is mostly shared with other engines, some of which produce a bit more torque.. |
| Copycat73 |
 Copycat73 World Chat Champion
| clancy |
 clancy World Chat Champion
 Posted: 19:19 - 23 May 2013 Post subject: |
As above really, probably not the best idea and probably won't get as good gains as youd expect. It will possibly just become less reliable as apposed to large enough gains to make it worth while, especially with massive distances
If your not restricted to what you drive howcome you don't take a more capable bike ? Esspecialy if your going two up  ____________________ KLX 300r |
| moonzoomer |
 moonzoomer World Chat Champion
| davidzweig |
 Posted: 07:10 - 24 May 2013 Post subject: |
Thought people would wonder why this bike..
Pluses:
-I rebuilt it from the frame up and know every screw and wire on it.
-Easy and cheap to find/scavenge parts pretty much anywhere if needed
-Light, decent clearance, robust: can handle bad roads
-Very good on fuel
-Big enough for the two of us
-Already has a luggage rack and a pair of well-fitting panniers.
-Has upgraded suspension, brakes, 12V socket and an HID headlight.
Minuses
-Oil changes are quite frequent.
-Unsuitable for motorways.. well, maybe can just keep up with the trucks, in which case alright.
-Not a lot of torque, have to use the gearbox to maintain speed.
-Worried about keeping up with traffic on inclines.
-Seems a bit vibey, got a new pair of compound grips and some bar-ends, will see if that helps..
The big bore kit would help quite a bit. Can anyone say if it is likely to fit? |
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:19 - 24 May 2013 Post subject: |
Hmm. Well, they're very specific about what it does and doesn't fit, which is reassuring.
I can recall a couple of folk who have fitted 150cc kits to their Chinese copyengines, and IIRC their opinion was that it helped a little bit on inclines but didn't give significantly more speed. I don't know anyone who's run one for an extended period of time, but I can't see any problems with it as that engine is run as a 150 in half the world anyway. ____________________ Biking is 1/20th as dangerous as horse riding.
| Clutchy |
 Clutchy World Chat Champion
 Posted: 08:32 - 24 May 2013 Post subject: |
I honestly don't think it will make much noticeable difference at all...
Other than possible mechanical issues?
But then again I've never understood why anyone would want to such a long trip on a tiny bike which is so slow
Each to their own, I wish you good luck ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 17:21 - 24 May 2013 Post subject: |
they run the 150s in thailand and india, most of asia, i can say for a fact that they do have a bit more balls than the 125, atleast over there they do, the asians never seem to have a problem with the 150 motors and carry stupid loads on them,
go for it i say, make sure you rejet to suit though ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| cb1rocket |
 cb1rocket World Chat Champion
| dangerousdave |
 dangerousdave Traffic Copper
 Posted: 00:48 - 25 May 2013 Post subject: Re: 150cc big bore kit for CG125 on eBay |
| davidzweig wrote: |
Those CG's are mega reliable anyway, can't see it being much of a problem, it's only 20% increase in capacity. Another way to look at it is that it's a brand new top end, to replace the worn top-end on your bike.
If you value reliability most then stay with the standard Honda bore and piston. That will just keep going as long as the gearbox has oil.
If you want tha bit more performance then you'll probably notice a difference with the big bore kit, but the quality is never going to be up to that of the original Honda part. Any top-end selling for under a hundred quid is never going to last like the genuine parts. ____________________ 1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50 |
| Alpha-9 |
 Alpha-9 Super Spammer
| dangerousdave |
| davidzweig |
| bladerunner |
 bladerunner World Chat Champion
| Tench |
 Tench L Plate Warrior
| davidzweig |
| stevo as b4 |
| Irn-Bru |
 Irn-Bru World Chat Champion
| i2ico |
 i2ico Two Stroke Sniffer
 Posted: 13:42 - 29 May 2013 Post subject: |
Go without the bore up kit!
CG is a a CG, great little bike, reliable, good MPG.
Itll make for a fun experience.
Good luck and hava a safe journey
CG for life  ____________________
Limitations are only what you make of them.
Current: ER5, Stolen/Recovered:Honda CG |
The last post was made 12 years, 234 days ago. Instead of replying here, would creating a new thread be more useful? |
