suzuki sv650s 2008 speedometer playing up :/ help please
burnleyman188...
PostPosted: 19:32 - 28 May 2013    Post subject: suzuki sv650s 2008 speedometer playing up :/ help please Reply with quote
hi advice urgently needed, the actual bit where it tells u my speed is playing up. most times it wil just sit at 0 and not move other times it wil flucuate between lots of different numbers. and some other times it can work fine work a number of miles.
any sugestions on what to check or anything
thanks
james
J.Cook
cb1rocket
PostPosted: 21:26 - 28 May 2013    Post subject: Reply with quote
check sensor and wiring from front wheel and check that it is plugged in ok. Might be corrosion settling in and the contacts need a clean
ian505050
PostPosted: 22:12 - 28 May 2013    Post subject: Reply with quote
speedo drive at the wheel sounds faulty, when replacing there are different types. Some will cause your speedo to read double and some will cause your speedo to read half speed make sure you get the correct one.
DrDonnyBrago
PostPosted: 13:06 - 29 May 2013    Post subject: Reply with quote
Had the same on my CBR600.
After dicking about with wiring etc, turned out the speed sensor was knackered. It worked fine upon replacement.
Az
PostPosted: 00:50 - 31 May 2013    Post subject: Reply with quote
Definitely your speed sensor if it's just the speedo messing around. May need replacement.
mysterious_rider
PostPosted: 09:31 - 31 May 2013    Post subject: Reply with quote
My koso did this, was proper dodgy wiring connections into the unit. Had to replace the whole thing with a different setup.
KAWASAKIIIII
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.25 - MySQL Queries: 15 - Page Size: 51.42 Kb
