1989 cbr600f carbs
matchless1957
PostPosted: 17:54 - 29 May 2013    Post subject: 1989 cbr600f carbs Reply with quote
Hi can anyone tell me how to take the carbs of a cbr600f , i have undone all the screws that hold the rubbers , but still seems stuck , total novice can anyone help
Suntan Sid
PostPosted: 18:03 - 29 May 2013    Post subject: Reply with quote
They're a bugga to get off!
If you're replacing them with new ones, just keep trying and prise them off anyway you can!
Either way they are not easy to get off or back on, brute force will, ultimately, get them on and off, there is no clever way to do it!
matchless1957
PostPosted: 18:12 - 29 May 2013    Post subject: cbr Reply with quote
thanks very much, they just need cleaning and i didnt want to break anything , i will try a bit harder, watch this space. Its a 1989cbr600f i forgot to say.
matchless1957
PostPosted: 18:37 - 29 May 2013    Post subject: cbr600f 1989 Reply with quote
Thanks for that they are off, i had to use a try leaver in the end , what happened to carful is best and not to heavey handed , that kind of went out the window , cheers
Suntan Sid
PostPosted: 22:59 - 29 May 2013    Post subject: Reply with quote
Cool
Had exactly the same with mine, brute force seemed to be the only way!
Timmeh
PostPosted: 09:42 - 30 May 2013    Post subject: Reply with quote
Indeed. At least you know they're not going to come off though.
matchless1957
PostPosted: 10:22 - 31 May 2013    Post subject: fuel Reply with quote
I cleaned the carbs out , i have an ultrsonic cleaning machine , put them all back on the bike and now there is fuel coming out of the fuel union , little brown plastic pipe at the front of the carb , is this a seal or float problem . 1989cbr600f , thanks
Timmeh
PostPosted: 11:50 - 31 May 2013    Post subject: Reply with quote
I presume you've split the bank to clean them?
Either you've shagged the o-ring or cracked the t-piece, they're made of bakelite and will be very brittle due to age.
matchless1957
PostPosted: 11:59 - 31 May 2013    Post subject: carbs Reply with quote
I didnt spilt them , just took the tops and bottoms off , clean needle and brass bits at the bottom with holes , it does feel wobbly in the hole , can you take it out without taking the carbs off, and just replace the o ring.
The last post was made 12 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 58.11 Kb
