| jordey |
 jordey Nitrous Nuisance
| Aff |
 Aff World Chat Champion
| Islander |
 Islander World Chat Champion
| jordey |
| jordey |
| Efes123 |
 Efes123 World Chat Champion
 Posted: 06:40 - 30 May 2013 Post subject: |
As you have no power, it should be relatively simple to find. Just follow your main live feeds between the ignition and the battery (and the main earth from the battery). And get a proper multimeter, they're only a fiver ____________________ Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD |
 Posted: 10:05 - 30 May 2013 Post subject: |
If you haven't got a multimeter you can do a lot with just a bulb and two bits of wire. ____________________ a.k.a 'Geri'
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 10:46 - 30 May 2013 Post subject: |
as other posters,just remember youre lucky as it appears to be a singular wire fault.
check all the connector blocks and electrical pins inside for cleanliness and tightness.
if its a fault from the generator earth you could link a wire from the engin/alternator case to the earth,but do all the simple stuff first..............fuse,charged battery etc.
if you dont have a meter then use a small bulb with two wires on it to test for 'continuity'.....e.g.put one wire on the engine/frame/battery earth and prod around with the other wire seeing if power is getting to the clocks/lights etc...... make sure you test with ignition switched on...........i'd take a poke and say that your engines not earthed to the frame/battery.
good luck... ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| jordey |
| jordey |
| Islander |
| jordey |
 Posted: 19:18 - 30 May 2013 Post subject: |
If you're getting power at the brown wire to the horn, then the bike is powered up and the switch is working, for power anyway.
Press the horn, does it go peep peep? ____________________ a.k.a 'Geri'
| jordey |
| Turkish |
 Turkish Crazy Courier
| jordey |
 Posted: 21:51 - 30 May 2013 Post subject: |
| Turkish wrote: | Sounds like you have the probes connected ass about face.
Connect the black lead to the negative terminal (or ground). The red lead will be your 'probing' wire.
With the probing wire, put it on the positive terminal - you should get battery voltage. Then check ignition switch, main relay (if present) and so on.
One side of the horn will be short to earth (Ohm function on meter), the other side should get battery voltage with the switch depressed - but then you would also hear it....
It sounds like the ignition isn't being switched on, hence nothing works, so trace this circuit. You'll be looking for a pair of wires (usually) being shorted in the on position.
Got a wiring diagram so I can be more specific? |
yeah youre right, was being an idiot and had the probes plugged in wrong.
just checked again, getting current from the battery, current from the positive battery cable at the fuse box, and current is going to the connection at the fuse box that then goes in to the loom. it doesnt seem to be going much further than this as theres nothing at the speedo connection and nothing at the connection for the switches. one of the wires from the fuse box doesnt look so good, could this be the problem?
(theres two bits of electrical tape where a new section of wire has been put in)
https://i40.tinypic.com/2ewmkau.jpg |
| jordey |
| jordey |
 Posted: 23:04 - 30 May 2013 Post subject: |
| jordey |
| Aff |
| Turkish |
| jordey |
| jordey |
| Aff |
The last post was made 13 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
