newuser who brings some wise lessons.......
fastyan
PostPosted: 19:21 - 01 Dec 2004    Post subject: newuser who brings some wise lessons....... Reply with quote
hi all - have just been introduced to this forum and thought i would say hello and bring along a few wise lessons that myself and my friends have 'learnt' over the years.
i've had a look around and definately up for rideouts/track days and the like (especially as a few of my usual mates have moved further away or are under the thumb....)
i'm sure a few of you could add some to the list as well.... lol
Lessons 1-19, from the motorcyclists guide of 101 things not to expect or do when motorcycling.....
Lesson 1:
One should not rely on the fact that 35 miles has been made on the reserve light, and expect to be able to repeat this feat, especially when needing to be somewhere on time; for example riding to work
Lesson 2:
One should not be surprised if a mere 28 miles has been achieved when ragging the bike on the reserve light
Lesson 3:
One should not wear all black on a warm day if there is the slightest possibility that the bike may run out of petrol and require a push to the nearest petrol station
Lesson 4:
One should not disregard (bit of Word thesaurus action there! - shift F7...) the difference in the roads adhesion when braking from a dry road onto a wet roundabout, when trying to get somewhere in a hurry cos they're late...!!!
Lesson 5:
One should make note not to accelerate too hard in low gears whilst overtaking, as it makes it difficult to steer when your front wheel isn't on the ground!!!
Lesson 6:
Unless you have a readily available supply of clean underwear, sliding the rear wheel of your bike off roundabout exits to the entertainment of other bikers is best left to the experts........ or the purchase of a cheap runabout to practice on first (or use a mates...)
Lesson 7:
Motorcycles do not fly, therefore do not expect your motorcycle to stay on the ground when accelerating hard over the top of an incline. Be aware that it is best wherever possible that you should try and stay attached to the motorcycle whilst it is airborne
Lesson 8:
When taking a corner and things just start to touch down, don't expect the bike to be able to lean much further (also make note to move feet as far back on the pegs as you can)
Lesson 9:
Don't expect the novice behind you to make it round the same corner you've just gone round at 70 mph....
Lesson 10:
When riding in a group make a note of the person behind you and check they are still there regularly (see lesson 9) as it has been known that riding in 'two's' has resulted in the rider behind you suddenly disappearing and to be to later found in a ditch
Lesson 11:
Be aware of slippery rabbits that may happen to be on exactly the same line you wish to take round a tight right hand corner when you're doing 50 mph. As this may cause you to inadvertently take a tighter line, as to avoid slipping on the said slippery dead critter, and end up nearer the white line than is comfortable with your head a few inches away from the oncoming articulated lorry....
Lesson 12:
Just because you and the person in front of you are riding fast bikes doesn't mean that they would move off from a junction when you would (or at least look to see if they've gone first)
Lesson 13:
After lubing your ignition barrel to relieve sticky keys with WD40... and upon arrival at work, do not remove and put the key in your mouth while walking into the office.....
Lesson 14:
Riding a one litre bike : I have decided what my R1's like... with the R6 I was conscious of the speed vs ground vs skin loss vs vegetative state ratios... but the R1 is like riding with the Grim Reaper as pillion!! - and he wants to get his knee down!!
Lesson 15:
See lesson 8 - also note that although it looks very cool that the slight touch of a titanium exhaust on the ground will produce more sparks than your pegs or knee sliders, the resulting slide and sparks from the rest of the bike following it down the road however does not look very cool
Lesson 16:
Although some mammals can run at over 40mph, it is impossible for a motorcyclist dressed in leathers and wearing their bike boots to (especially in a gravel trap) - although the result does look funny when attempted
Lesson 17:
Whilst filtering through traffic you should keep an eye on the person filtering in front of you - otherwise if they happen to stop all of a sudden (as e.g. a coach may be blocking the traffic light) then you do not want to be using their luggage to activate your front brake and therefore end up sliding past them with the front wheel locked
Lesson 18:
If a bike is having trouble to start then the first thing to check is the kill switch - otherwise the colour of the language to be found coming out of your mouth after you have been trying to bump start it for a while may not be pleasant for passers by..
Lesson 19:
Despite friends vast knowledge of specific brands of motorcycles and their ownership of similar motorcycles don't expect them to remember small details like what a Yamaha ignition key looks like. Expectancies such as these often leave you confused and dazed as to why you can't turn the key in the ignition barrel.
Lesson 20:
If you are going to fall off/crash a motorcycle then you should ensure that it is yours (or pre-agreed that it won't matter). Crashing your dad's motorcycle is not recommended (especially if you still live at home and/or are trying to get your knee down for the first time)....
Shaun
Likes 'em bent
PostPosted: 19:33 - 01 Dec 2004    Post subject: Reply with quote
I've already read lessons 1 through to 16, I'm guessing you work with Helen, I feel your pain! Wink
Barker-CBR 600
PostPosted: 21:03 - 01 Dec 2004    Post subject: Reply with quote
Lesson 18:
*ammendment*
And the auto resetting immobiliser Evil or Very Mad
Previous - Gilera DNA50 / XVS125 Dragstar/Honda CBR 600F/GSF 650 Bandit
Current - 2013 Suzuki VZ800 Intruder
'Is this a rhetorical question?'
Fortuna
PostPosted: 21:19 - 01 Dec 2004    Post subject: Reply with quote
Or "try taking your R1 out of gear numb nuts".
mrchips
PostPosted: 21:23 - 01 Dec 2004    Post subject: Reply with quote
One I've learnt the hard way is don't wash your plug during your bike wash, and then expect to ride it two minutes later.
Northern Irish? www.nibikers.com
PostPosted: 21:33 - 01 Dec 2004    Post subject: Reply with quote
Lesson 21: I am NOT Valentino Rossi. I am NOT Valentino Rossi. I am NOT Valentino Rossi. I am NOT Valentino Rossi.
Rob W
PostPosted: 21:41 - 01 Dec 2004    Post subject: Reply with quote
LOL, made me chuckle that one Thumbs Up
Nighteyes
Dirty Bint
PostPosted: 22:48 - 01 Dec 2004    Post subject: Reply with quote
Cheeky bitch!! Laughing
Welcome aboad Ian, looking forward to see you kick Shaun's ass at BCF ride outs. Razz Thumbs Up
*waves manically*
My Precioussss!, My Bikes, The Lord & Master, Canis Lupus!
39. Something nice about the person who sent this to you? She's beautiful, funny, and has a huge heart. Very Happy
Silver
PostPosted: 22:51 - 01 Dec 2004    Post subject: Reply with quote
Too bloody right. We can't both be him... Very Happy
fastyan
PostPosted: 16:38 - 02 Dec 2004    Post subject: Reply with quote
shaun - you guessed correct... as for the pain (no comment Wink )
Nighteyes
Dirty Bint
PostPosted: 19:56 - 02 Dec 2004    Post subject: Reply with quote
Nasty......nasty boys!! Crying or Very sad
Razz
Marc_Buck
PostPosted: 20:07 - 02 Dec 2004    Post subject: Reply with quote
Welcome mate.
94 fzr600r
Annabella
Like a person, only smaller
PostPosted: 21:13 - 02 Dec 2004    Post subject: Reply with quote
Hello!!
*me follows Helen's example in waving, with additional bouncing*
Well done at recuiting girl Thumbs Up
Be good to see you at some of the Midlands meet.... round's on you at the Braddy first Monday of summer? Wink
Avast! Pirates ahoy!
I did Cadwell! Very Happy
fastyan
PostPosted: 22:02 - 02 Dec 2004    Post subject: Reply with quote
lol first round..... erm ... yeah... sure........ erm....... erm......
<but you did say summer..... britain..... not much chance there then..>
Shaun
Likes 'em bent
PostPosted: 22:59 - 02 Dec 2004    Post subject: Reply with quote
You might not start going meets again until summer when you get back here but the rest of us will go a long time before that and you'll miss out on drinks! Razz
I never did say welcome to the forum, welcome! Very Happy
Annabella
PostPosted: 23:03 - 02 Dec 2004    Post subject: Reply with quote
Oi Shaun!
I suggested biking things Christmas and Boxing day.... Razz I'll be wanting drinks then too. In the mean time you can woo me by purchasing drinks on Saturday, for myself and Helen Wink
Shaun
Likes 'em bent
PostPosted: 23:18 - 02 Dec 2004    Post subject: Reply with quote
Will do, hope you two like tap water.
Nighteyes
Dirty Bint
PostPosted: 01:03 - 03 Dec 2004    Post subject: Reply with quote
Woohoo! Dance!
You've got no chance though Ann, I've been waiting for a drink owed off him for a good 6 months before now. Rolling Eyes
Shaun
Likes 'em bent
PostPosted: 06:22 - 03 Dec 2004    Post subject: Reply with quote
What do you expect, you have stupidly priced drinks.
CBRPETER
PostPosted: 08:01 - 03 Dec 2004    Post subject: Reply with quote
lol.. Many o lessons have i learnt the hard way, probably the worst was thinking i was in my power band when i wasn't, i quickly discovered just how quickly the front wheel can fly.
Shes my life, shes so rad and shes the best ride i ever had!!
Nighteyes
Dirty Bint
PostPosted: 22:20 - 03 Dec 2004    Post subject: Reply with quote
Well I had to charge the interest somehow! Razz
The last post was made 21 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 120.32 Kb
