caliper bolt head worn out
Random13
PostPosted: 14:02 - 23 May 2013    Post subject: caliper bolt head worn out Reply with quote
Hi,
I was trying to service my sym and open the calliper to clean it etc.
Because I did use Allen key to open the bolt i did damage the bolt head then went to buy the socket allens which did open one of the bolts and not the other
So I am left with drilling it out unless someone else has other suggestion
So then two questions which all answers are highly appreciated are
1. Any suggestion on how to drill it?
2. Considering my bike is sym and not as popular and available in the market, would I be able to get the bolts only or have to buy the whole calliper ?
[img]https://img818.imageshack.us/img818/1912/img11991i.jpg[/img]
[URL=https://imageshack.us/photo/my-images/254/img12021.jpg/][IMG]https://img254.imageshack.us/img254/4973/img12021.jpg[/IMG][/URL]
also on the other side of caliper there is another bolt which not sure what it does but also managed to damage that so may have to buy that as well. i do not need to drill it out as can use pair of pliers to pull it out
[URL=https://imageshack.us/photo/my-images/842/img12031.jpg/][IMG]https://img842.imageshack.us/img842/6007/img12031.jpg[/IMG][/URL]
PostPosted: 14:12 - 23 May 2013    Post subject: Reply with quote
That's not a bolt it's a pin. If you can't get the other one out you'll have to drill it but you'd better buy a replacement first because it's not a standard item, you can't just fit any old bolt as a replacement.
groovylee
Fixed it for you.
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
Random13
PostPosted: 14:28 - 23 May 2013    Post subject: Reply with quote
Thanks buddy, what was the issue anything i was doing wrong
PostPosted: 15:36 - 23 May 2013    Post subject: Reply with quote
Just warm the area around the head with a plumber's torch - no need to get it piping hot just warm it up to about 60-70 degrees and the bolt should come undone.
Random13
PostPosted: 17:15 - 23 May 2013    Post subject: Reply with quote
so let me guess the two pins one of which has a worn head is to keep the pads in place but the other pin on the other side of the caliper is for pads to hang on it or something ? does that need to be taken off ?
i am thinking of seperating the caliper and then use the home gas to warm it up or hot water maybe . wd40 etc didn't work
i am struggling to get hold of the part. looking to see if cg honda will fit in,
btw how did you fix the images ?
PostPosted: 17:17 - 23 May 2013    Post subject: Reply with quote
Looking at how the one you have in your hand is dried out on the end, not on the thread, I would heat up the casting on that side rather than the threaded side, or do both.
Random13
PostPosted: 10:49 - 26 May 2013    Post subject: Reply with quote
thanks mate
Random13
PostPosted: 14:36 - 03 Jun 2013    Post subject: Reply with quote
have tried all but can not remove it . there are 2 pins which have gone through the pads which if i do not remove both can not then remove the pads to heat the pin etc
here is a pic of the head, do you have any suggestions on how to remove it
[IMG]https://i40.tinypic.com/2ujmbtk.jpg[/IMG]
PostPosted: 15:05 - 03 Jun 2013    Post subject: Reply with quote
You and spanners are not a match made in heaven are they?
Birkonian
PostPosted: 23:36 - 03 Jun 2013    Post subject: Reply with quote
That is the same brake unit that I have on my Poineer XF200. These pins can be troublesome.
If you do manage to remove it successfully, it would be worth replacing the pins with Stainless Steel ones which you can get on ebay, or yo can buy the whole unit:
https://www.ebay.co.uk/sch/i.html?_odkw=motorcycle+caliper+pins&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0&_nkw=chinese+motorcycle+caliper+pins&_sacat=0[/url]
Regards
Jim
The last post was made 13 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.55 - MySQL Queries: 13 - Page Size: 77.27 Kb
