curtain poles
Dalemac
PostPosted: 22:42 - 04 Jun 2013    Post subject: curtain poles Reply with quote
So I have bought my first house with the girlfriend, and there are no curtain poles. I go to drill some holes above the window and only get as far as the plasterboard.
Seems like my hammer drill and masonry bits are not up to the task of drilling the concrete lintel. What options do I have? Perhaps an sds drill will be up to the task?
Cheers.
YBR125 -> GPZ500S -> SL1000
oldpink
PostPosted: 22:47 - 04 Jun 2013    Post subject: Reply with quote
more than likely its the drill bit and not the drill
had a similar issue but went and bought a good Tungsten carbide masonry bit did the job Thumbs Up
Dalemac
PostPosted: 08:43 - 05 Jun 2013    Post subject: Reply with quote
I bought a brand new masonry drill bit and it made zero difference.
Beings as i have to put curtain poles up on every window in the house i may as well just go for an SDS drill and get it over with.
Dale
Islander
PostPosted: 08:44 - 05 Jun 2013    Post subject: Reply with quote
SDS drill required - assuming there's no steel involved of course. An SDS drill provides a greater percussive force than a hammer drill. Thumbs Up
angryjonny
PostPosted: 08:55 - 05 Jun 2013    Post subject: Reply with quote
Or put the curtain pole an inch or two higher so you're drilling into brick not concrete. If you're drilling into the lintel you're awfully close to the window box.
Sako
PostPosted: 09:48 - 05 Jun 2013    Post subject: Reply with quote
Have you tried gaffa tape or pva glue?
Dalemac
PostPosted: 09:49 - 05 Jun 2013    Post subject: Reply with quote
Ahh, now there is a suggestion.
I drilled yesterday at 8cm above the window, there is only another 7cm above that before the coving for the ceiling is reached. (15cm from window to coving).
Its an ex council house built around 1955. What is the likely height of the lintel?
If I try again, at say 12 or 13cm, think I will have better luck or just have a load of holes in the wall? Embarassed
I also have some spare bricks - i'll try drilling one tonight with the current drill to see if the drill will be ok with brick.
DrDonnyBrago
PostPosted: 11:20 - 05 Jun 2013    Post subject: Reply with quote
You sure they are concrete lintels?
Had a similar brain fart in my old dear's house when my masonry bits came out covered in steel filings.
J4mes
PostPosted: 12:02 - 05 Jun 2013    Post subject: Reply with quote
Does the plasterboard have much of a gap behind it?
You might be able to put plasterboard fixings in rather than having to drill all the way in to the blockwork.
Dalemac
Positive. Concrete dust everywhere after spending 15 minutes drilling and only getting a centimeter into the concrete.
Aikman666
PostPosted: 12:15 - 05 Jun 2013    Post subject: Reply with quote
Is it out of the question to mount the curtain pole on a nice bit of wood and then no more nails the wood to the wall? Seems to be how the landlord done it in my place.
Otherwise when I'm at work (home store) I use plasterboard fixings to mount all the curtain poles there and they are plenty strong enough - assuming there's clearance enough of course.
Will work for petrol
My Design Blog
Dalemac
PostPosted: 12:22 - 05 Jun 2013    Post subject: Reply with quote
Nope, the plasterboard is flush to the wall, no cavity.
I would prefer not to no more nails it together, and the extra bit of wood would be a bit nasty in my opinion. Thanks for the input though.
growler
PostPosted: 16:43 - 05 Jun 2013    Post subject: Reply with quote
know it may seem a stupid question but the house is brick and not no fines concrete?
DILLIGAF
robs321
PostPosted: 16:56 - 05 Jun 2013    Post subject: Reply with quote
Go hire, or borrow and SDS drill for the day!
andyscooter
PostPosted: 16:58 - 05 Jun 2013    Post subject: Reply with quote
our lintals have a metel lattice surround on them
i found this out by hitting one with a drill and bending the very hot drill bit 90 degrees leaving me a 3 inch wide hole to look in
my house is a late 60's house though
Dalemac
PostPosted: 16:59 - 05 Jun 2013    Post subject: Reply with quote
Nope, definitely a brick built house !
J4mes
PostPosted: 17:44 - 05 Jun 2013    Post subject: Reply with quote
"No more nails" the pole fittings to the wall?
Proper Pikey!
Dalemac
PostPosted: 08:19 - 06 Jun 2013    Post subject: Reply with quote
Last night i managed to drill the supports at either side of the window bay as they are just brick, but even so it wasn't easy.
Gonna have to buy an SDS drill to get the job done i think.
The lintel must be huge - i drilled another hole in the middle of the bay as high as i could (13cm) and it was still concrete!
J4mes
PostPosted: 09:02 - 06 Jun 2013    Post subject: Reply with quote
I got a £40 240v Hammer SDS from B&Q about 5 years ago, and it has been brilliant around the house and even when contracting doing electrical installation work (as long as I have access to 240V of course!)
Great for drilling bricks, blocks, cement and it has rotary-stop so you can use an SDS Chisel for chasing out walls or knocking tiles off
angryjonny
PostPosted: 09:27 - 06 Jun 2013    Post subject: Reply with quote
I've gone through my 8" thick reinforced concrete drive with my SDS drill and a chisel as a jackhammer. Awesome piece of kit but I warn you, if you get one, you'll be going round looking for things to knock holes in,.
Dalemac
PostPosted: 11:04 - 06 Jun 2013    Post subject: Reply with quote
I have ordered a SDS from screwfix - should be here tomorrow.
https://www.screwfix.com/p/titan-ttb278sds-5kg-sds-drill-240v/97533
I'll let you know how it goes, but it had over 200 reviews and 4-5 star ratings, so im hoping it will be able to cope!
The drill i bought is a little bigger than i would have liked for this kind of job, but i only have to drill two holes in concrete lintel and soon i might be ripping up a couple of inches of concrete, so bought it with that in mind.
loply
PostPosted: 13:58 - 06 Jun 2013    Post subject: Reply with quote
Why not just no-more-nails a piece of timber trim above the window then screw your curtain poles into that?
The trim is usually painted with gloss white and makes it easier to change poles later.
Yamaha SZR660 Caution to the wind, the throttle pinned!
Tarmacsurfer
PostPosted: 14:06 - 06 Jun 2013    Post subject: Reply with quote
I was under the impression that site work required 110V gear?
I'm immortal. Well, so far.
fatpies
PostPosted: 14:12 - 06 Jun 2013    Post subject: Reply with quote
I thought this was going to be a Krad esq post, as in certain Poles.
J4mes
PostPosted: 14:19 - 06 Jun 2013    Post subject: Reply with quote
Private contracting, not site work Thumbs Up
The last post was made 13 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 122.83 Kb
