Balancing a wheel? balancing a windmill prop?
Ribenapigeon
PostPosted: 08:27 - 07 Jun 2013    Post subject: Balancing a wheel? balancing a windmill prop? Reply with quote
I'm fettling a windmill to generate power (I know nuts) but I'm wondering how to go about balancing it as I'm going to fettle the prop myself. I'm thinking someone here by knowing about balancing wheels might have some advice on how to proceed.
Cheers.
PostPosted: 08:39 - 07 Jun 2013    Post subject: Re: Balancing a wheel? balancing a windmill prop? Reply with quote
I'd suggest you should be looking at people who balance propellers, not wheels.
With a wheel you just add weight at the exact point needed to counterweight how much it's out by.
If you have an external disc around the tips of your blades this may well work, otherwise it's getting each blade set up right.
Ribenapigeon
PostPosted: 08:59 - 07 Jun 2013    Post subject: Reply with quote
I lknow I need to add weight but the problem is how to find the right spot and how much weight to add.
PostPosted: 09:33 - 07 Jun 2013    Post subject: Reply with quote
With balancing anything, you generally allow it to spin freely and mark the lowest point when it comes to a halt then repeat. If the same point lands up lowest you either remove weight from that point or add weight to the highest point.
Then repeat. If it stops at the same point, you need to add/remove more weight. If it stops opposite, you need less. It's balanced when it comes to rest at a different point each time.
With a vehicle wheel, you'd stick/cinch small lead weights to the rim or (the old fashioned way) wrap bits of solder round a spoke.
With a crank, you'd either drill holes in the flywheel or grind the outside of the flywheel to lighten it.
With a windmill prop. Not sure how they'd do that. Maybe add weights to the hub?
True before you balance.
PostPosted: 10:11 - 07 Jun 2013    Post subject: Reply with quote
Something like that:
https://www.thebackshed.com/windmill/articles/turbinebalance.asp
james1988
PostPosted: 10:26 - 07 Jun 2013    Post subject: Reply with quote
I did some work experience years back in stage 2 compressors (I think that's the right term) for the GE90. To balance the turbine it was a case of swapping the blades for a heavier or lighter blade. No idea if that's of any use.
James
Ribenapigeon
PostPosted: 10:41 - 07 Jun 2013    Post subject: Reply with quote
I did wonder if it involves a certain amount of dead reckoning then trial and error with weight placement. So thanks for confirming it.
The kind of prop I'm going to make will be more of a barral with vanes on somewhat like a centrifugal type, if that makes sense, so it spins whatever the wind direction.
PostPosted: 10:51 - 07 Jun 2013    Post subject: Reply with quote
That type you should be able to balance with weights like a wheel as they generally do have a couple of rings to keep everything held together.
Ribenapigeon
PostPosted: 10:55 - 07 Jun 2013    Post subject: Reply with quote
I'm thinking two aluminium discs then pop rivet vanes between them.
yen_powell
PostPosted: 11:27 - 07 Jun 2013    Post subject: Re: Balancing a wheel? balancing a windmill prop? Reply with quote
Cheers.
The most important thing is to have the right hat.
https://trumpton3.homestead.com/CambwPeople/Windy__.JPG
XT1200Z and a DR350 in bits
DrDonnyBrago
PostPosted: 12:00 - 07 Jun 2013    Post subject: Reply with quote
I balance wheels using a shaft running on a set of bearings, two bearings on each side with the shaft resting between them, pop out the seals and replace the thick grease with light oil and they become very free running.
Basically a DIY version of these:
https://www.harborfreight.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/i/m/image_12675.jpg
https://www.motorcyclenews.com/upload/Knowhow/sep28%2005%20balance%20wheels/4-01.jpg
Heavy bit falls to the bottom, place weights directly opposite.
Can't see why it wouldn't work for you.
Ribenapigeon
PostPosted: 12:49 - 07 Jun 2013    Post subject: Reply with quote
I'm going to balance it after i've mounted it in a frame. i've found some skateboard bearings on amazon that are a good source of cheap bearings.
I can see the logice of just turning the wheel then seeing where it comes to rest and will probably use that method. But what are they doing in tyre fitters when they spin the wheel up to high speed on that machine they have.
PostPosted: 12:52 - 07 Jun 2013    Post subject: Reply with quote
The same thing, except it has a strain guage in the pin the wheel is rotating on to electronically show them which side is off balance and by how much.
james1988
PostPosted: 13:41 - 07 Jun 2013    Post subject: Reply with quote
Just a thought, haven't you got to get the pitch of the prop / fan blades the correct angle too?
James
PostPosted: 14:24 - 07 Jun 2013    Post subject: Re: Balancing a wheel? balancing a windmill prop? Reply with quote
Cheers.
Don't just balance the fan - balance the assembly.
Built your wind generator and set it at a low level on a flexible pole. Get it spinning somehow (by wind, pony motor drive or self-powered if it can) and have a dial gauge fixed alongside and touching the genny housing. If it's out of balance you'll see a constant sine movement on the dial gauge. Now weight one of the blades and see if the movement on the gauge is more or less. Keep adjusting the weight or position of the weight until the dial gauge does not move when it's spinning.
This won't give you perfect 'dynamic' balancing but it'll get you a long way along the road, and should be enough to give a long lifespan. The only hard part is finding something solid next to the tower to mount the dial gauge to.
Here is a pic of me balancing a motor pulley this way recently. I used a stack of magnets and washers on the inside lip of the pulley and moved them around, noting the dial reading at each point until it was smallest then adjusted the weight until it was zero:
PostPosted: 14:26 - 07 Jun 2013    Post subject: Re: Balancing a wheel? balancing a windmill prop? Reply with quote
Or if you're a lazy bugger, mount it on big rubber blocks.
Ribenapigeon
PostPosted: 15:27 - 07 Jun 2013    Post subject: Reply with quote
James
As its not going to be spinning too fast I don't think this is as critical as overall ballance. Not too difficult to make sure blade pitch/angle is regular though anyway. Good point though.
Ribenapigeon
PostPosted: 15:30 - 07 Jun 2013    Post subject: Reply with quote
Pete, I will probably do some sort of assembly ballance tests as well but nice to start with a balanced prop to start with.
PostPosted: 15:33 - 07 Jun 2013    Post subject: Reply with quote
Yes having the blade pitches all the same is important. It's easy to make a cardboard template for doing that. You have to make sure that's right before doing any balancing otherwise you'll be adjusting weight balance to correct wobble from varying effort.
mudcow007
PostPosted: 16:01 - 07 Jun 2013    Post subject: Reply with quote
is this of any help?
The last post was made 12 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.36 - MySQL Queries: 13 - Page Size: 108.33 Kb
