| Ribenapigeon |
 Ribenapigeon Super Spammer
| G |
 G The Voice of Reason
| Ribenapigeon |
| stinkwheel |
 Posted: 09:33 - 07 Jun 2013 Post subject: |
With balancing anything, you generally allow it to spin freely and mark the lowest point when it comes to a halt then repeat. If the same point lands up lowest you either remove weight from that point or add weight to the highest point.
Then repeat. If it stops at the same point, you need to add/remove more weight. If it stops opposite, you need less. It's balanced when it comes to rest at a different point each time.
With a vehicle wheel, you'd stick/cinch small lead weights to the rim or (the old fashioned way) wrap bits of solder round a spoke.
With a crank, you'd either drill holes in the flywheel or grind the outside of the flywheel to lighten it.
With a windmill prop. Not sure how they'd do that. Maybe add weights to the hub?
True before you balance. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| G |
| james1988 |
 james1988 World Chat Champion
| Ribenapigeon |
| G |
| Ribenapigeon |
| yen_powell |
 yen_powell World Chat Champion
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| Ribenapigeon |
| stinkwheel |
| james1988 |
| Pete. |
 Pete. Super Spammer
| stinkwheel |
| Ribenapigeon |
| Ribenapigeon |
| Pete. |
 Pete. Super Spammer
 Posted: 15:33 - 07 Jun 2013 Post subject: |
Yes having the blade pitches all the same is important. It's easy to make a cardboard template for doing that. You have to make sure that's right before doing any balancing otherwise you'll be adjusting weight balance to correct wobble from varying effort. ____________________ a.k.a 'Geri'
| mudcow007 |
 mudcow007 World Chat Champion
 Posted: 16:01 - 07 Jun 2013 Post subject: |
The last post was made 12 years, 307 days ago. Instead of replying here, would creating a new thread be more useful? |
