Honda CG125 Choke problem "HELP!!"
leonadele
PostPosted: 14:20 - 07 Jun 2013    Post subject: Honda CG125 Choke problem "HELP!!" Reply with quote
I have recently done my CBT and got an old CG125, which runs lovely but has a weird problem.
when it gets up to a good speed, the choke comes on by itself!
obviously this can lead to a loss of power, which isnt nice when trying to overtake a wagon!
Has anyone had this problem before?
Please help!!
mudcow007
PostPosted: 14:25 - 07 Jun 2013    Post subject: Reply with quote
eh?
to turn choke on push the lever up, when the lever is down its off
so is the lever jumping up?
treeno
PostPosted: 02:19 - 09 Jun 2013    Post subject: Re: Honda CG125 Choke problem "HELP!!" Reply with quote
Please help!!
I have the same on my CG. It happened after I cleaned the carb out and lost the ball bearing that holds the lever in place. If you look it has 3 little holes in it. Anyway, I haven't bothered to find a replacement so have just tied it down, it's fine during the warmer months. Could probably fix it easy.
leonadele
PostPosted: 06:20 - 11 Jun 2013    Post subject: Reply with quote
Thanks for that
My problem is the bike is 21 years old, and needs some choke in the morning, even in good weather so tying it down isnt really an option
I will have to check for this bearing and see if it needs replacing
Thanks again!
DMCpro
PostPosted: 08:18 - 11 Jun 2013    Post subject: Reply with quote
Hi mate if you use a rubber band you can hold the choke up untill you don't need it
Honda CB-1, TS125X
VW Golf Estate
tomh
PostPosted: 08:27 - 11 Jun 2013    Post subject: Reply with quote
I fixed this problem by removing the single screw holding the choke lever and its metal plate. The metal plate has 3 holes cut into it for each position of the lever. I bent the plate slightly with two pliers, refitted it and I also made sure the screw was in tight.
If the lever is to worn this wont work but you could try putting some electrical or Teflon tape on the pivot for the choke lever to stiffen it up.
leonadele
PostPosted: 13:10 - 11 Jun 2013    Post subject: Reply with quote
Thanks, i think the electrical tape sounds like the easiest solution!
cg125erinit
PostPosted: 09:19 - 12 Jun 2013    Post subject: Reply with quote
Anyone else totally dig that the bike is so damn old and so still bloody working, that the choke lever has literally worn out?
CG4lyfe yo! Thumbs Up (and probably my grand kids too)
leonadele
PostPosted: 10:32 - 12 Jun 2013    Post subject: Reply with quote
I agree!!
Plus the fact that it usually just takes just a spanner, screwdriver or gaffer tape to keep it going!!
leonadele
PostPosted: 17:20 - 12 Jun 2013    Post subject: Reply with quote
Bent the plate, and put a washer on as well, this seems to have sorted the problem
Many thanks to everyone for your advice
Nick_Giles
PostPosted: 22:25 - 12 Jun 2013    Post subject: Reply with quote
mudcow007 wrote:
eh?
Some CG's apparently were made the opposite.
The one I had however was the same as yours. i.e. down was off.
Nick
The last post was made 12 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 71.35 Kb
