Aprilia RS125 with 154 bore kit
kmeister
PostPosted: 23:44 - 09 Jun 2013    Post subject: Aprilia RS125 with 154 bore kit Reply with quote
Hi guys, recently picked up a 2003 RS125 where the previous owner has fitted a mitaka 154cc big bore kit to it. Was an unfinished project so I'm currently in the process of sticking it back together and one thing that came across my mind is the jetting. It's the 32mm carb and has a 162 main jet, anyone know a rough starting point with the 154cc?
I've also got the old 125 barrel with it which is in great condition so not put off by perhaps refitting it with a fresh piston. From reading around there seems to be mixed opinion on fitting the bigger bore kits.
Clutchy
PostPosted: 00:42 - 10 Jun 2013    Post subject: Re: Aprilia RS125 with 154 bore kit Reply with quote
The bin? Unfinished project on those kinds of bikes normally means, i've fucked around with it so much that a mechanic doesn't want to touch it for less than £400 which I don't want to spend...
My advice is use the 125 barrel and get a new piston/rings, they're unreliable just being stock at the best of times, not sure I'd want to put a bore kit on it that's been half done! Rolling Eyes Neutral
PostPosted: 07:00 - 10 Jun 2013    Post subject: Reply with quote
32mm carb is small. The standard derestricted RS one is 34mm.
Unless you know exactly what you are doing (evidently not as you are asking on the forum...) I wouldn't even attempt it.
kmeister
PostPosted: 08:30 - 10 Jun 2013    Post subject: Reply with quote
Sorry it's 34mm. I understand jetting, I race a kart which uses the same engine and carb so I know what to look for there. Just wanted a very rough idea of where to start with the jetting. Thanks anyway, probably just going to restore it to the original cylinder as I'd rather seek reliability than performance.
evoboy
PostPosted: 09:53 - 10 Jun 2013    Post subject: Reply with quote
Completely the wrong bike then! Laughing
I should have shares with Mitaka the amount of new complete top ends ive fitted to them. £200 a pop un all.
Use the standard jetting for that carb on that engine in that bike. Use the standard airbox and airfilter. If its on the standard pipe, itll probably be reliable.....ish.
APT Motorcycles
Clutchy
PostPosted: 10:21 - 10 Jun 2013    Post subject: Reply with quote
Well if he races a snr Max, at least the unreliability of the rs won't come as a shock Wink
kmeister
PostPosted: 10:33 - 10 Jun 2013    Post subject: Reply with quote
Haha, I mean a reliable-ish toy! I won't be relying on it as a commuter, just using it as a small footstep into the bike world for a bit of fun on a nice summer's day. Plus I like to tinker so it's a nice little project to work on Smile
Previous owner has faffed with the exhaust, it's all welded up so I assume it has had some gubbins removed. Is it safe to assume that the 162 main jet in the carb is probably what was fitted when it had the original head? I've a selection of jets in this range from my kart so can tweak from there.
PostPosted: 10:35 - 10 Jun 2013    Post subject: Reply with quote
Probably had the cat and shit pulled out. Would have been easier to grab an old 2000 models exhaust or an aftermarket one.
stevo as b4
PostPosted: 17:22 - 10 Jun 2013    Post subject: Reply with quote
If it's not your only road bike, blowing it up isn't a big worry, and you wanted to throw good money after bad on a 2stroke project bike, then I might consider using the 154 Polini kit. If the kit is new and the crank has been recently re-built properly, you might get 8-10'000miles from a well set up 154cc conversion. It will be a ballache and need dyno time most likely to set up the jetting.
From what I've read the 154cc Polini is claimed to give they say about 37bhp, so low 30's at the back wheel. They never do by the sounds of it, as the kit increases the mid-range power and has a silly high compression ratio, that actually reduces top end performance. The 125cc suited expansion chamber won't ever ideally suit the 154 kit, and you would probably end up with a more vibey rougher motor, that is better in the midrange but not much if any better at the top end. You lose revs with the Polini kit, possibly due to factors such as the porting design and compression ratio, but also because the exhaust isn't 100% suited to the bigger cc top end. Maybe you can gain the speed back with higher gearing, but the fastest tuned bikes seem quicker at 125cc with professional tuning.
Would think the 34mm carb is big enough, and that as baseline maybe 2-3sizes up on the main jet would be ample to ensure rich running until properly tuned.
Good luck whichever way you go with it, but having a decent 125cc top end spare and being able to re-build it properly with decent quality parts seems by far the best way to go.
kmeister
PostPosted: 18:08 - 10 Jun 2013    Post subject: Reply with quote
Thanks for all the replies, good to get some input Smile
I've decided my plan of action is to get the engine back in as is, get her all wired up and make sure it's going to turnover and run. My gut feeling at the moment is once it's running, swap the head over to the 125 with a fresh piston and rings. As I say won't be relying on it as a daily commuter but would like to have some confidence that I'll make it A-B and back to A now and again Laughing I'm not overly fussed about extra performance, it's my first bike so I'm sure even in standard form it would have enough power for me!
Looking forward to getting it back together!
The last post was made 13 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 66.06 Kb
