SV650 Heavy heavy clutch...
Clutchy
PostPosted: 17:24 - 11 Jun 2013    Post subject: SV650 Heavy heavy clutch... Reply with quote
DO sv's have very heavy clutches normally? Either was this cannot be normal what I've got, my arm/tendons are in agony after just an hours ride, quite hard to pull the clutch in and after a while its taken its toll.
Anyway to make this less so? Is it just a case of slackening the cable or is it time for a new one?
Maybe needs lubing somewhere? Help!
PostPosted: 17:25 - 11 Jun 2013    Post subject: Reply with quote
My GSXR required 2 hands once Shocked
Cable will need lubing, perhaps also the actual worm gear that actuates the push rod.. there should be an adjuster on there also.
Clutchy
PostPosted: 17:35 - 11 Jun 2013    Post subject: Reply with quote
Cheers, will copper grease do?
PostPosted: 17:37 - 11 Jun 2013    Post subject: Reply with quote
For the cable, no idea.
For the worm gear, no idea.
I just used a bit pot of grease that my dad has. Laughing
PostPosted: 18:23 - 11 Jun 2013    Post subject: Reply with quote
No. Copper grease has slivers of copper in it, which are abrasive. Copper grease should be used for applications with minimal movement and high temperatures.
Use LM grease to grease the linkages, and 3 in 1 to oil bowden cables. However, if the cable is so screwed that you're getting arm pump from pulling the clutch, I'd suggest replacing the cable.
Fizzer Thou
PostPosted: 18:40 - 11 Jun 2013    Post subject: Reply with quote
I use one of these with GT85 teflon spray lube
https://www.ebay.co.uk/itm/MOTORCYCLE-MOTORCROSS-MOTORBIKE-CYCLE-CABLE-OILER-LUBRICATOR-TOOL-NEW-/400458979493?pt=UK_Motorcycle_Parts&hash=item5d3d3718a5
Also,make sure that the pivot bolt area is clean and properly lubricated with the proper grease (not copaslip).
Halfords sell bearing and high melting point grease.It is always handy to have a pot of each in the cupboard for not much outlay.
Always have a 'Plan B'
Blue_SV650S
PostPosted: 19:27 - 11 Jun 2013    Post subject: Reply with quote
I guess it depends on what you are expecting/used to, but no, the SV doesn't have a notably heavy clutch.
Assuming your cable is free to move (check that) a massive difference - positive or negative - can be made with adjustment of the worm gear mechanism. There is a locknut and flat head screw arrangement that adjusts the 'slack' in the system.
Do you have a manual for the bike? The angle the little arm is set to is critical to good operation of the clutch. The clutch can feel horrible, even 'problematic' if that angle is out.
The correct way to adjust the clutch is to wind out the lock -nut mechanism, set the arm angle via the cable adjusters, then re-adjust the lock-nut mechanism so it has just a little slack.
The last post was made 13 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 53.44 Kb
