right turn lowside again, am I doing it wrong?
Val
PostPosted: 23:24 - 13 Jun 2013    Post subject: right turn lowside again, am I doing it wrong? Reply with quote
Right turn lowside two days...again, it happens on yearly basis for me the last 4 years. Tradition which I do not like to keep.
Need your advice guys do I need to book some track days to master my right turn?
Here is what has happened: right turn on unknown twisty road, decreasing radius bend, me obviously going too hot, trying to lean more realize this is not helping enough, so I try a tiny bit of back brake, obviously not tiny enough, me losing control lowside with some trail style pathetic attempt with my right foot to save it, not working enough in the final phase just dropping the bike, angry as hell.
In same scenario I do have tried the front brake previously the result was bad, I have tried last year a little bit off throttle, big mistake Smile
The question is do I need finally to do some track day and try to master this decreasing radius right bend?
How do you guys do it if you are too hot in such decreasing radius bend? Throttle off - unsettle the bike, any brake front or back - again unsettle the bike?
reed
PostPosted: 23:27 - 13 Jun 2013    Post subject: Reply with quote
You sound like you'd be much better off with 4 wheels mate. Thumbs Up
Generic XOR 50, Gilera SMT 50, GSXR 400 GK73A, Ducati Monster 600, Honda Hornet 600.
Sold. Stolen. Written off. Sold. Current.
keggyhander
PostPosted: 23:29 - 13 Jun 2013    Post subject: Reply with quote
One's bravery should never exceed one's skills.
nightshaddow
PostPosted: 23:29 - 13 Jun 2013    Post subject: Re: right turn lowside again, am I doing it wrong? Reply with quote
there is your problem right there
my instructor always told me gentle roll on the throttle (yes speed up) transferring the weight onto the back wheel, lean in, and trust the bike,
always worked for me Thumbs Up
Sako
PostPosted: 23:30 - 13 Jun 2013    Post subject: Reply with quote
Just lean it more and push the inside bar, keep arms relaxed and focus on exit, bike will make it.
nightshaddow
PostPosted: 23:32 - 13 Jun 2013    Post subject: Reply with quote
https://www.youtube.com/watch?v=bVWNinsmkAw
Spudly
PostPosted: 23:33 - 13 Jun 2013    Post subject: Reply with quote
I'm gonna say add more lean and more throttle, but I'm prepared to be sneered at.
The physics wold tell me that increasing lean will decrease the turn radius, while increasing throttle will engage centripetal force and keep the bike from falling over. Obviously you will have to find a balance, but seems to me that the counterintuitive response will be the correct one.
The Old Apprentice
Slacker24seve...
PostPosted: 23:34 - 13 Jun 2013    Post subject: Reply with quote
Were you properly on it or were you just pootling and it took you by surprise?
It sounds like you need to turn in later. Slow in, fast out. Get on the gas when you see the vanishing point widen.
Have you got a street view/google maps picture of it? If it was a decreasing radius turn then hedges/trees/telegraph poles could have given clues, in which case poor obs.
Banger rallies are ace
Val
PostPosted: 23:42 - 13 Jun 2013    Post subject: Reply with quote
just pootling actually, it was nice sunny day I was just enjoying the ride not paying any attention and it definitely took me by surprise...
J.M.
Go slower on unknown roads. You don't know what mysteries are hiding behind the corners or what the corners are hiding in themselves.
Braking in a corner unless applied with some very forceful countersteering is going to make you go wide. Lean and throttle on to go tight.
Braking hard with the rear brake in an attempt to slow down for a decreasing radius corner is a big no no. You run the risk of locking the rear and... well... low-sliding!
2004 R1 & 2018 XSR900
Val
PostPosted: 23:45 - 13 Jun 2013    Post subject: Reply with quote
Thanks that is exactly what I think would be right to do, I need to try this next time Laughing
Musketeer
PostPosted: 00:08 - 14 Jun 2013    Post subject: Reply with quote
I'm no expert so don't eat me alive.. but I always fight against my survival instincts and it's worked so far.
I usually don't go into bends too hot but shit happens sometimes i.e. I had that on the way too Wales a few days ago when I had a bend that was pretty much over 150 degrees, downhill with guiderails on the side of it but I didn't expect it to be that kind of bend so I approached it like I do 90 degree bends. And then it was like 'oh shit'.. but I DID NOT TOUCH brakes. I did everything else, trying to keep big chunk of the weight on my rear tyre (not easy to fight instincts), lean to the inside, countersteer, and.. prayed that I would make it without hitting the kerb/rail.. It's especially scary when you go down the hill at the same time, it makes it so uncomfortable feeling that you think there is way too much weight on your tiny front tyre that in split second mind tells you keep your throttle steady, but instincts tell to let the throttle go and that it's already too late and you are going to crash haha.
So I guess the important thing is.. NOT TO PANIC, BECAUSE YOU'RE ALREADY FUCKED.
It's kinda funny how many things you can think of in split second when adrenaline is pumping Wink
Also as people above said.. go slower on unknown roads, don't exceed your skills.
PostPosted: 07:33 - 14 Jun 2013    Post subject: Reply with quote
You have to open the throttle progressively and smoothly after you turn in to a corner. If you crash when doing that, you're going too fast.
PostPosted: 08:17 - 14 Jun 2013    Post subject: Reply with quote
Then you know exactly what your problem is, and you're not going to sort that on a track.
floydwaters
PostPosted: 08:51 - 14 Jun 2013    Post subject: Reply with quote
When I'm riding twisties that I'm unfamiliar with I use the satnav with no destination programmed, it gives you an idea of how sharp the bends are on the road ahead.
Works for me, now all I need is an app for gravel.
Triumph Tiger 1050
We have no destination and its wonderful...
1cyl
PostPosted: 09:02 - 14 Jun 2013    Post subject: Reply with quote
All this guff about more lean less break more throttle. Pah. Every bends different.
OP. Get out there and find some less used roundabouts Thumbs Up
I've never been as confident with my rights as my lefts, still can't back it in half as well as I can a left hander.
The 3 F's teach me everyday : Focus, Feel, Faith
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Ichy
PostPosted: 09:18 - 14 Jun 2013    Post subject: Re: right turn lowside again, am I doing it wrong? Reply with quote
valko wrote:
trying to lean more
Not enough. You probably feel that the bike is leaning over all the way when in fact it is just a few degrees. If nothing has ground out then you still have plenty of (designed) room to go.
Don't change anything once you have committed, any braking or acceleration will unsettle the bike in some way and you do not yet have the skill to control it.
What bike is it? If it is the same you you keep falling off then have a look at fitting some proper tyres.
Easiest way to fix it? Slow down. Read up on vanishing point. I haven't read all this but it is a start https://www.cvam.info/index.php?page=main.tips_roadcraft_vanishing. Basically, go as fast as you can safely see. Improve you observations. Road markings for instance, more paint means a bigger danger.
Ichy
PostPosted: 09:21 - 14 Jun 2013    Post subject: Reply with quote
In principal I can see what you are doing but while you are studying the sat nav you are not looking at the road. I've yet to own a GPS that says "Dead badger in 10 meters".
Sako
PostPosted: 09:42 - 14 Jun 2013    Post subject: Reply with quote
Bad idea, learn to read the road, good roadcraft will equal progressive riding.
yaigi
PostPosted: 09:57 - 14 Jun 2013    Post subject: Re: right turn lowside again, am I doing it wrong? Reply with quote
That's exactly what I was told too, and has worked for me. When I've taken a bend at what I think is a bit too fast if you could plug a microphone into my brain you'd hear me saying to myself "Don't you dare come off the throttle or touch the brakes, don't you dare..."
The one time I did touch the brakes (on my 125, around a roundabout, before I was told what to do if I thought I had approached a turn too fast), I fell off Thumbs Up
clancy
PostPosted: 11:23 - 14 Jun 2013    Post subject: Reply with quote
As above, trusting the bike is absolute key in corners
Never touch the breaks, terrible idea, you dont wanna roll off the throttle either because that transfers weight to the front wheel which can put you on the floor. You need to either keep the throttle consistent through the bend to keep the weight transfer the same or accelerate so it's all on the back wheel
Also I don't know how you ride you may do it anyway but If you feel the bikes leaning too far remember you can lean off of the bike a considerable distance, leaving the bike more upright giving better grip
KLX 300r
fozzym
PostPosted: 11:56 - 14 Jun 2013    Post subject: Reply with quote
The simple and most effective answer in to slow down..... Seriously, if you don't know the road then just take it a bit easier, look well ahead and keep your eyes peeled for clues of whats to come. If the road is particularly twisty then expect the next blind bend to be sharp even though it might not be.
Is it really worth pushing things if you don't know the road, just slow down and enjoy the ride. Better to take a bend at 50 and think I could have done it easy at 60 than shit your pants round at 70.
Like others have said if you do get caught out and we all do, just trust the bike and lean her over more. But even when I have been caught out its never really been near a crash, just a case of oh shit this bend is a bit sharper than I thought, better throw her over a bit more.
One thing I have found doing track days is that I go more steady on the roads, you will never match the thrill of the track on the road so I don't even try. I find a different pleasure on the roads and thats just the pleasure of being out there enjoying being on the bike, speed in the bends isn't on my agenda.
Slacker24seve...
PostPosted: 12:47 - 14 Jun 2013    Post subject: Reply with quote
This. I'm a terrible rider when I'm dawdling on twisty roads. I came upon a BMW R-Sofa 1200 thing with nowhere to pass on a twisty bit. I ended up following him for a bit and got into a pickle half concentrating and following his lines. Wobbling and 50-pencing ensued. Trackdays won't help your road riding much when you're not on it, other than to explore just how much further you can lean it and how quick you can pull up when you need to.
I'll say it again, you took too much speed into the corner and poor obs for not spotting the severity of it.
Dalemac
PostPosted: 13:07 - 14 Jun 2013    Post subject: Reply with quote
Took you by surprise?
If it was such a bad bend then you would have been forewarned by road signs.
Signs such as:
https://www.accountancyage.com/IMG/414/60414/double-bend-ahead-uk-road-sign-1-370x229.jpg?1246441591
https://www.britannia-driving-school.co.uk/images/tt/rightturn.jpg
https://www.signservicesuk.com/online/thumb.php?src=products/large/1210857727_P7104.jpg&wmax=300&hmax=400&quality=100&bgcol=FFFFFF
Perhaps you should also improve your observations and understand why these signs are there?
YBR125 -> GPZ500S -> SL1000
Wave2k
G's Stalker
PostPosted: 13:11 - 14 Jun 2013    Post subject: Reply with quote
id put money on the fact after going into the corner to hot, your are leaning on the front brake.
Bad enough to come off the throttle going into a bend hot as all the weight surges forward anyway, add a little brake its a recipe for disaster.
Throttle control is key for cornering, its the difference between being upright and on your ass sometimes.
Ducati 1299 Panigale
2009 Corvette C6 z51
The last post was made 13 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 136.21 Kb
