Garage security
-Matt-
PostPosted: 20:14 - 17 Jun 2013    Post subject: Garage security Reply with quote
Thinking of moving to a new flat soon, going to have a garage a bit like this
https://media.rightmove.co.uk/4k/3513/24198003/3513_PAR120606_IMG_06_0000_max_620x414.JPG
Anyone know of any security devices to recommend to secure the door. Was thinking of something like this but didnt know how effective and reliable they really are.
https://www.safelocks.co.uk/acatalog/garage_defender.jpg
Don't want to walk out one morning and find the local chavs have had the door up and all my gear and bikes are in pieces on ebay Rolling Eyes
Cheers Thumbs Up
Tungtvann
PostPosted: 20:45 - 17 Jun 2013    Post subject: Reply with quote
If they want it, they'll have it, but it'll slow down the determined and deter the casual. Although it may highlight the fact you have something of value in the garage.
-Matt-
PostPosted: 20:49 - 17 Jun 2013    Post subject: Reply with quote
Motion sensor laser-gun is always an option i guess Mad
J.M.
PostPosted: 20:50 - 17 Jun 2013    Post subject: Re: Garage security Reply with quote
Hey guys, look at me, I've got something valuable inside!
2004 R1 & 2018 XSR900
Ollie1995 This post is not being displayed because the poster is banned. Unhide this post / all posts.
Mark65
PostPosted: 20:52 - 17 Jun 2013    Post subject: Reply with quote
I have a Garage Defender, have done for 10 years now, they would need serious cutting kit and make a lot of noise to get past it, well worth the money and its a visual deterrent. Make sure the base is in concrete.
Mark
Kierran
PostPosted: 21:00 - 17 Jun 2013    Post subject: Reply with quote
I wouldnt have anything external showing value with. I'd reinforce the door with scaffold poles, rebar mesh or simila materials affixed, welded etc to the existing frame. Then dead bolts top bottom and sides. How secure is the roof?
Im not driving too fast, Im flying too low!
Current Bike - GSXR 750 K5
Current Car - BMW 318i
-Matt-
PostPosted: 02:38 - 18 Jun 2013    Post subject: Reply with quote
Thanks mark useful to hear of experience with the defender. As a few mentioned i was also worried in some ways as it obviously does highlight probably valuable contents, but on the other hand - if its anyway like where i'm living currently an unsecured door sooner or later WILL get opened and pi--ed inside/burned/vandelised in some form or another along with the contents of the garage Mad
The problem with the garage is its a one door entry only [front main door], so the internal security like dead-bolts etc i presume wouldn't be suitable, or am i misunderstanding how you install/access them Confused
Cheers all Thumbs Up
Kierran
PostPosted: 03:43 - 18 Jun 2013    Post subject: Reply with quote
Horizontal bolts could be easily linked to a rotating handle in the center. Vertical bolts could be set up like this
https://www.youtube.com/watch?v=D9hSp2FClIA
using some type of long life battery to power them hooked up to a simple key fob.
Looked into this a wee while ago when i was offered a garage that i eventually didnt get.
Im sure the tech dudes on here would assist on a project like this just out of curiosity of the outcome.
jetski
PostPosted: 04:34 - 18 Jun 2013    Post subject: Reply with quote
I have the same type of garage and they are remarkably easy to break in to. that lock pictured is a good one, go for that. if you want more security you could put padlocks and bolts high up. no point putting them low as a bolt cutters can easily be used.
I wouldn't worry about the lock advertising that you have something worth stealing as locals will eventually see you going in and out of there at some point. I could break in to the garage as standard in less than 10 seconds.
I may be worth using a disk alarm aswell as inside the garage it will be loud as hell.
you could build a proper cage front just inside out of steel bars jail style, but it would be a lot of work
woo look at me, I'm a signature
CaNsA
PostPosted: 06:54 - 18 Jun 2013    Post subject: Re: Garage security Reply with quote
Just hit me a few times with a sledge hammer and you can have it all.
PostPosted: 08:15 - 18 Jun 2013    Post subject: Reply with quote
I have a garage defender, I bought it after my garage in a block was broken into.
The policeman who came around said he had never seen a garage with a garage defender successfully opened. I reinforced the bottom edge of my garage door with 1" box section steel too, and I've also got a hasp and tang padlock bolted to the floor as a double deterrent.
I doubt you'd get past the garage defender with a sledgehammer. Maybe with hydraulic cutters or an angle grinder, but at the end of the day if they can break the garage defender they can break anything. I've also got a xena alarmed chain looped through all of my bikes inside.
PostPosted: 08:17 - 18 Jun 2013    Post subject: Reply with quote
Run electric to the garage and move in.
The only way to stop people from stealing your shit.
-Matt-
PostPosted: 09:37 - 18 Jun 2013    Post subject: Reply with quote
Thanks again for all the info Thumbs Up
Looks like ill be turning the place into a bank vault then Laughing
Linux
PostPosted: 09:48 - 18 Jun 2013    Post subject: Reply with quote
fishing wire and rape alarms, home alone style.
Two wheels are all I need.
Gazz
PostPosted: 11:31 - 18 Jun 2013    Post subject: Reply with quote
Should keep thieves at bay:
https://t0.gstatic.com/images?q=tbn:ANd9GcS_UTZtDDdm2LGOwhKvWhGyHhDxPMKxvdWGC_zoP1XmCNFtaLUJOLATkXCcSA
-Matt-
PostPosted: 11:33 - 18 Jun 2013    Post subject: Reply with quote
I've got that side of things covered
https://1.bp.blogspot.com/-fUvNRrJo7yM/TiMbNV0-2_I/AAAAAAAAB2k/MWq1eF05HUQ/s1600/Don%25E2%2580%2599t+Ever+Gives+a+Loaded+Gun+to+Monkey.jpg
Speed
PostPosted: 11:42 - 18 Jun 2013    Post subject: Reply with quote
Garage door bolts would be better. Fitted to the inside of the door makes it a secure, hidden locking setup.
https://www.lockmonster.co.uk/images/products/1985/images/Pacri%20Garage%20Door%20Bolts%201%20Pair.jpg[/list]
BTTD
https://www.ebay.co.uk/itm/Enfield-Garage-Door-Bolt-Locks-MK-II-/321037048220
Not very noticeable from the outside. Used in addition to a defender or other padlocks and hasps and you're a long way on from a standard door.
Edit: Speed beat me to it.
Minty
PostPosted: 11:58 - 18 Jun 2013    Post subject: Reply with quote
As quoted above, those old 70's style garage doors are easy to get into at the bottom corners by basically peeling them back.
Brother lost a load of power tools etc using that method.
My fingers smell of your mum.
PostPosted: 12:02 - 18 Jun 2013    Post subject: Reply with quote
Those bolts are shit, had those and the door was bent at each corner where the bolts were. Since then I've had a garage defender for the past six years, at two different addresses and haven't been broken into.
BTTD
PostPosted: 12:57 - 18 Jun 2013    Post subject: Reply with quote
So did the bolts fail, or was the garage door made of tinfoil?
I would've thought that a defender in the middle of the door would still allow the corner to be bent up and tools robbed, but I guess the door can't be opened.
PostPosted: 13:02 - 18 Jun 2013    Post subject: Reply with quote
That's why I reinforced the bottom of my door with 1" box section which coincidentally fitted perfectly in the little U shaped recess in the bottom of the door.
I've seen those bolts before, and as they generally mount onto the sheet metal of the door rather than the framework, the tea leaves just cut around them. The garage defender is the best option as far as I can tell.
PostPosted: 13:08 - 18 Jun 2013    Post subject: Reply with quote
The door was bent due to being made of tinfoil.
Bending the corners of the door is for the purpose of opening the door rather than to steal tools that are within reach. The garage defender prevents the door from being opened so the bending of corners doesn't happen.
-Matt-
PostPosted: 15:49 - 18 Jun 2013    Post subject: Reply with quote
Would it be simpler instead of faffing with reinforcements/bolts and the rest to maybe just get two garage defenders one either side, or do they have to be position in the centre of te door Confused Obviously might look a bit o.t.t but would at least make the door virtually inpenetrable wouldnt it Laughing
Probably find they rent the garage next door and tunnel down and up through the floor having done that mind Rolling Eyes
The last post was made 13 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 127.36 Kb
