| mattgreene |
 mattgreene L Plate Warrior
| Nope. |
 Nope. World Chat Champion
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 00:35 - 19 Jun 2013 Post subject: |
sounds like a main or singular fault. Check the fuse and the main wires you can see and make sure the solenoid and starter,if fitted isnt earthing out .
Then check all the bulb fittings for corrosion and then if still nothing......check the ignition switch and generator coil.
Depending on the wirin of a bike , it can still run with knacked power / charge / lighting coils if it has a seperate spark/genny power coil so if there's no loose wires or dicky ignition switch then check the charging and lighting coils. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| mattgreene |
There is a gap of 292 days between these two posts... |
| Danielkayy |
 Danielkayy L Plate Warrior
 Posted: 23:35 - 07 Apr 2014 Post subject: Re: HONDA XR125 - I turn the key and nothing happens |
take the headlight and surround off and check all connections had the same problem took them off sparayed abit of wd40 and puit them back in started perfect  |
| moonzoomer |
 moonzoomer World Chat Champion
| SQL |
 SQL World Chat Champion
The last post was made 12 years, 205 days ago. Instead of replying here, would creating a new thread be more useful? |
