bike chain space between sprocket and chain
stranger12
PostPosted: 22:44 - 18 Jun 2013    Post subject: bike chain space between sprocket and chain Reply with quote
Hi All,
While adjusting my chain, I took a picture of my chain which shows that you can almost stick a screw drive between the sprocket and the chain despite the chain having only 20 to 25 mm of play
This is the case on my 125 but not on my bigger bike
Is that normal ?
Here is a pic for your information
https://i40.tinypic.com/jueqgg.jpg
SV650 Red
R6 Red
PostPosted: 22:51 - 18 Jun 2013    Post subject: Reply with quote
I wouldn't have it that loose. Have you checked the slack all the way across the chain by rotating the rear wheel and checking the tension again say 1/6th the way round?
Basically, check tension everywhere.
YBR Ric
PostPosted: 22:56 - 18 Jun 2013    Post subject: Reply with quote
It's normal when the chain/sprocket is worn Sad
Before chain wear stickers started appearing on some bikes and weighting the chain and measuring a specific number of links became De rigeur,
the old rule of thumb was that if a pencil could fit into the gap it was time for replacement.
stranger12
PostPosted: 23:05 - 18 Jun 2013    Post subject: Reply with quote
i should say the chain had done 12k and i took 2 or think 3 links out so could get it tight again
it was streched all the way before taking links out
SV650 Red
R6 Red
barrkel
PostPosted: 23:19 - 18 Jun 2013    Post subject: Reply with quote
Don't do that; that's a very bad idea.
The chain stretches such that the link length no longer matches the tooth pitch of the sprockets. Removing links does nothing to fix this. This mismatch in link length vs tooth pitch concentrates all the force of the engine on the first few teeth engaged, rather than all around the sprocket, meaning both the chain and sprocket wear at an accelerating rate, no matter how much you try to re-tension the chain.
So you'll be looking at missing teeth - far more likely on the front sprocket, you may have lost some already and not noticed it if you haven't removed the front sprocket cover - or a snapped chain before long. A chain in the process of snapping is no joke. It could seize the rear wheel leading to a high-side, it could eat through the engine block leading you to need to replace the engine, it could even slice into your leg, causing you to have a very bad day.
Walloper
PostPosted: 04:00 - 19 Jun 2013    Post subject: Reply with quote
Stretched + Removing links = Shagged.
Replace Splokets and Chain. Think of the kittens you heartless bastirt..
cimbian
PostPosted: 09:27 - 19 Jun 2013    Post subject: Reply with quote
No, don't remove links just accommodate stretching. New chain time (and possibly sprockets).
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
stranger12
PostPosted: 10:42 - 19 Jun 2013    Post subject: Reply with quote
so you think that the chain links are now bigger than it was before(stretched) and thus not fitting on the sprocket ?
if that is the case, i will change them all ( sprocket and chain).
why do you think that the chain will snap ? it may come off but wouldn't snap i think
SV650 Red
R6 Red
PostPosted: 14:28 - 19 Jun 2013    Post subject: Reply with quote
Er, yes. Why do you think you needed to take links out?
A chain is a bunch of links with holes in the ends, and pins through those holes to hold the links together. "Stretching" is when those holes start to wear and get bigger. You're literally losing metal from your chain, and the bigger the holes get, the more the pins can worry at them as load comes on and off.
Stupid, messy, high maintenance archaic technology, I wish more manufacturers would fit shaft or belt drive.
J.M.
PostPosted: 14:32 - 19 Jun 2013    Post subject: Reply with quote
Stretched and poorly maintained chains do snap. I can guarantee a few people on this forum have had it happen to them, hence the warning to you Smile
2004 R1 & 2018 XSR900
stranger12
PostPosted: 14:40 - 19 Jun 2013    Post subject: Reply with quote
i shall swap it then weekend
thanks again and sorry wan't sure when a chain stretched what causes this. the explanation makes a perfect sense
SV650 Red
R6 Red
stranger12
PostPosted: 15:20 - 19 Jun 2013    Post subject: Reply with quote
one thing , i guess it will snap due to the wear on the pin hols becoming so big so one link is just going to brake thus come off , am it correct ?
SV650 Red
R6 Red
Shinigami
PostPosted: 15:25 - 19 Jun 2013    Post subject: Reply with quote
12k miles, slack on the sprockets, definately time for it to be changed out, sprockets too.
Alpha-9
PostPosted: 15:41 - 19 Jun 2013    Post subject: Reply with quote
You mad bro, don't think of the kitten but think of your chain strain and the inevitable pain game if it snaps
Fzr-600 1999
Walloper
PostPosted: 16:54 - 19 Jun 2013    Post subject: Reply with quote
Chains can be a hassle but I've never had any problems like wot I red on here with my chains. I have had to fit new sprockets and chain to bikes I have got 2nd hand. But they are relatively simple to maintain if the correct shit and regime is employed. Esy get 20k out a decent quality chain. Unless you start dicking with sprocket sizes suspension settings, shocks and the service lifetime expectancy can change.
You need a big wide belt to carry the same load as a 1/2 wide chain so the pulley width would have to be considered.
On those Cement Mixers the Muricans go all weak over the belts are 3"- 4" wide.
I'm not sure what Buell fit.
iMark
PostPosted: 17:18 - 19 Jun 2013    Post subject: Reply with quote
Chain like that.. with links removed?
Check your front sprocket.. it's gonna be like claws lol Smile
Time to replace everything !
K8 GSXR 1000
Acemastr
PostPosted: 08:38 - 20 Jun 2013    Post subject: Reply with quote
This is so dangerous it's unbelievable, I'm surprised the chain hasn't already ripped your leg to shreds from snapping.
2016 Toyota Tacoma Limited
cb1rocket
PostPosted: 09:45 - 20 Jun 2013    Post subject: Reply with quote
If properly tensioned and the like it should be fine. You should see how some people have worn the sprockets to just a ring with no teeth! Now that's dangerous!
Walloper
PostPosted: 10:04 - 20 Jun 2013    Post subject: Reply with quote
No teeth is dangerous?
If no teeth no go. No go no danger. Sorted. Thumbs Up Very Happy
stranger12
PostPosted: 18:56 - 29 Jun 2013    Post subject: Reply with quote
Just thought I post back.
I did change the whole set and now all seems good and happy .
Although the new chain had some lubricant which think was oil on it but again I did apply lubricant to it
thanks all for your help
SV650 Red
R6 Red
barrkel
PostPosted: 21:34 - 29 Jun 2013    Post subject: Reply with quote
I got from Germany to the UK at motorway speeds with no teeth on the front sprocket of my ER6f.
The teeth don't snap off such that they leave a smooth circle. There are normally little stumps left behind, and if the chain is tight enough, it will grip. Try to drive too much torque and the chain will skip though, so you need to take it gently.
Walloper
PostPosted: 09:19 - 01 Jul 2013    Post subject: Reply with quote
It was a joke man... Rolling Eyes
Sako
PostPosted: 09:54 - 01 Jul 2013    Post subject: Reply with quote
Chain would have been coated in wax.
stranger12
PostPosted: 21:52 - 01 Jul 2013    Post subject: Reply with quote
would the chain stretch caused any power loss?
SV650 Red
R6 Red
janner_10
PostPosted: 07:09 - 02 Jul 2013    Post subject: Reply with quote
This - Its time for a new chain and sprockets - simple as.
The last post was made 13 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 128.28 Kb
