what to check after riding through large pot-hole
Wonko The Sane
PostPosted: 19:33 - 19 Jun 2013    Post subject: what to check after riding through large pot-hole Reply with quote
Just ridden through a huge pot-hole at 40mph as I didn't spot that the drain cover was slightly sunk with a huge pot hole just the other side of it.
didn't think I had time to swerve so stood up and eased off, bike thumped through it with the usual noise you'd expect from being bumped about.
handling doesn't seem to have been affected, don't think there's any play in the forks but was wondering what else I should check.
bike is a zzr600 if that's relevant.
Marmalade
PostPosted: 19:53 - 19 Jun 2013    Post subject: Reply with quote
Check the rims for dents, my gsxr had a massive dent in rear wheel after hitting a pot hole
red5
PostPosted: 19:54 - 19 Jun 2013    Post subject: Reply with quote
Fillings and testicals are where they are supposed to be. lol.
Check wheels are true and no dents on the rims, Also check tyre pressures now and again in the morning.
callum94
PostPosted: 20:29 - 19 Jun 2013    Post subject: Re: what to check after riding through large pot-hole Reply with quote
Same thing happened to me at 55mph, the whole bike made a massive crunch and painful shockwaves went straight up both arms.
I think the main thing is what the others have said about checking the rim (I was lucky), also make sure your tyre is not loosing any air like previously stated.
Current: CBR 125R 2012 (Black)
Restricted licence (33hp): 09/12/12
Wonko The Sane
PostPosted: 22:38 - 19 Jun 2013    Post subject: Re: what to check after riding through large pot-hole Reply with quote
I've got a spare set of rims so should be ok :p
Dave70
PostPosted: 22:52 - 19 Jun 2013    Post subject: Reply with quote
+1 for testicals Thumbs Up Very Happy Thumbs Up
Although, you'd probably notice pretty instantaneously if you had done any damage to those. I have ended up with my eyes watering on one or two occasions myself before now. Crying or Very sad
moonzoomer
PostPosted: 22:53 - 19 Jun 2013    Post subject: Reply with quote
Check your steering head bearings for play and check that the bearing cups are not cracked, as already posted check wheels for damage and strange as it may seem check your rear sprocket mounting bolts for tightness or breakage.
Wonko The Sane
PostPosted: 07:38 - 20 Jun 2013    Post subject: Reply with quote
Need to get front end in the air to check head bearings?
She ran smooth for a few meters no hands without any juddering, slapping or wobbling afterwards
Dodders
PostPosted: 09:44 - 20 Jun 2013    Post subject: Reply with quote
Similar thing happened to me the other day on the Bandit, had been running with a little bit of misting on one fork leg but after the pothole that seal was leaking a good'un and is now back in the shed waiting for new seals. Just one more thing to check maybe...
LockyUK
PostPosted: 14:30 - 20 Jun 2013    Post subject: Reply with quote
destroyed my front wheel, massive flat spot, council refused to pay out for the repair
pepperami
PostPosted: 17:17 - 20 Jun 2013    Post subject: Reply with quote
I hit a large pot-hole and a slightly raised drain cover in the space of half a metre this year.
I was doing ??? MPH and I was braking hard due to the rabbit doing a silly dance in the middle of the road.
The result was burst fork seals Shocked , so they might be worth checking.
Scootaloo
PostPosted: 17:25 - 20 Jun 2013    Post subject: Reply with quote
I find putting down some power just before hitting a pot hole is a bit better? as it raises the front "over" the hole and the back will follow.
Not sure if this logic is correct though.
(CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
SQL
PostPosted: 18:45 - 20 Jun 2013    Post subject: Reply with quote
I do that for speed bump I can't avoid Thinking
Snorty
PostPosted: 19:03 - 20 Jun 2013    Post subject: Reply with quote
Until your back tyre goes over it fully loaded with the weight taken off the front.
Slacker24seve...
PostPosted: 20:55 - 20 Jun 2013    Post subject: Reply with quote
Pull a stoppie as soon as the front is over the pothole?
No?
Laughing Laughing
Banger rallies are ace
Snorty
PostPosted: 21:15 - 20 Jun 2013    Post subject: Reply with quote
No?
Laughing Laughing
I've always thought about doing this for those spike strips the police use. Obviously they don't use them on bikes but I still wonder if you could do it.
The last post was made 13 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 91.37 Kb
