Stomp Grip Install
j.silvs
PostPosted: 20:18 - 20 Jun 2013    Post subject: Stomp Grip Install Reply with quote
Hello all,
I have received some black stomp grips for my gsxr. I keep reading about people getting air bubbles.
Will I be able to see air bubbles on the black one?
Also, any tips for the install?
PostPosted: 20:19 - 20 Jun 2013    Post subject: Reply with quote
Clean area as best you can. Apply it from one end, don't just stick it.
j.silvs
PostPosted: 20:21 - 20 Jun 2013    Post subject: Reply with quote
Ok cool, anything specific to clean it with?
PostPosted: 20:27 - 20 Jun 2013    Post subject: Reply with quote
Some people use alcohol stuff, personally I just use a polish duster thing, square yellow thing Laughing
PostPosted: 20:29 - 20 Jun 2013    Post subject: Reply with quote
Just get them stuck on. I had ones cut in half on one of my old track bikes as they didn't make the correct ones at the time. They're function more than form.
Slacker24seve...
PostPosted: 20:45 - 20 Jun 2013    Post subject: Reply with quote
Rubbing alcohol would be perfect. Brake cleaner would probably do it too.
Banger rallies are ace
fozzym
PostPosted: 21:49 - 20 Jun 2013    Post subject: Reply with quote
Not sure whether it applys here but I always use a bit of fairy in water in a trigger spray. works with stickers and rim tape ect.
Just spray a fine mist on the area enough to wet it and then apply sticker. It gives you some scope to move the sticker around and squeegee out bubbles. Once the fairly solution dries the sticker sticks as normal or better.
Dean-J
PostPosted: 00:08 - 21 Jun 2013    Post subject: Reply with quote
use a tennis ball to "rub" the grip on and remove the air bubbles. works very well. youtube it Wink
Current: 99 Yamaha Thuundercat
Previous: K7 GSXR 1000 K4 GSXR 600 roadbike, CBR 600 Steelie Track bike, 2005 SV1000Sz, 2004 FZ6 Streetfighter,2003 Yamaha Thundercat, 2002 SV650, 1989 Yamaha DT125R
The Tot
PostPosted: 00:26 - 21 Jun 2013    Post subject: Reply with quote
Apply with a bit of heat. Hairdrier does the job nicely to make it more malleable. Removes the air bubbles.You can peel off and reapply with the safety of heat.
Never argue with autism
The last post was made 13 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 58.05 Kb
