Seized Swingarm Spindle
SQL
PostPosted: 19:26 - 21 Jun 2013    Post subject: Seized Swingarm Spindle Reply with quote
Can't get my swingarm spindle out to replace, tried soaking it hitting it.
anyideas?
The other Paul Rudd
PostPosted: 19:38 - 21 Jun 2013    Post subject: Reply with quote
Angle grinder. Good luck.
PostPosted: 20:07 - 21 Jun 2013    Post subject: Reply with quote
https://rogerborg.dnsd.me/thunder-hammer.jpg
james1988
Tried using a drift while hitting it? May make some difference, though I'm not sure if any.
James
Honda XL1000VA '07
Copycat73
PostPosted: 20:12 - 21 Jun 2013    Post subject: Reply with quote
use a propane blow torch on the areas around the bushes.
caveat emptor
Islander
PostPosted: 21:04 - 21 Jun 2013    Post subject: Reply with quote
This ^^^
With a freeze spray on the spindle as well.
SQL
PostPosted: 21:05 - 21 Jun 2013    Post subject: Reply with quote
using a drift mate the spindle is counter sunk its a bitch only thing holding it is whatever it is seized against
PostPosted: 21:19 - 21 Jun 2013    Post subject: Reply with quote
Drain oil and fuel, lay the fucker on a mattress and get maximum hammer powah.
stickybackbob
PostPosted: 21:44 - 21 Jun 2013    Post subject: Reply with quote
If you can't bash it free, see if you can get a hacksaw between the swing arm and frame to cut it. Once out, you can heat to the seized bits to get them out.
SQL
PostPosted: 21:47 - 21 Jun 2013    Post subject: Reply with quote
lol trust me paddy I have been using a club hammer and drift the fucker aint moving Sad
Quote Me Happy
PostPosted: 22:03 - 21 Jun 2013    Post subject: Reply with quote
You need a bigger hammer.
PostPosted: 22:26 - 21 Jun 2013    Post subject: Reply with quote
https://www.aspli.com/products/635/carters-14lb-sledge-hammer?gclid=CNCm_6uL9rcCFWLHtAodej0AGA
SQL
PostPosted: 23:55 - 21 Jun 2013    Post subject: Reply with quote
ITS OUT, had to drill the engine mounting and use acf50 in the hole then it gave up after a while
SQL
PostPosted: 00:55 - 22 Jun 2013    Post subject: Reply with quote
well i did use a 2lb lump hammer so ya bigger hammer but not of thor quality.
The last post was made 13 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 82.09 Kb
