HISS
Aff
PostPosted: 13:19 - 21 Jun 2013    Post subject: HISS Reply with quote
Quick question.
Can I start tapping into my ignition wires for a switched voltage, or is this going to play havoc with the HISS?
Would I be better off taking it from the lighting circuit or something?
Electric Bike Project
J.M.
PostPosted: 13:35 - 21 Jun 2013    Post subject: Reply with quote
I'd always take it from the tail light. That way, should something go wrong, you've only lost your taillight. Nothing too bad.
2004 R1 & 2018 XSR900
stonesie
PostPosted: 14:59 - 22 Jun 2013    Post subject: Reply with quote
I would also run the extra circuit from a relay, so the feed from the lighting circuit has almost no extra load on it and whatever accessory's you are fitting take power from the battery through a suitable fuse.
Manufacturers are known to use wiring that's just upto the job, add more load to it and it can cause issues.
Walloper
PostPosted: 16:54 - 22 Jun 2013    Post subject: Reply with quote
Tail light tap and relay (as belt an' braces).
Aff
PostPosted: 17:30 - 22 Jun 2013    Post subject: Reply with quote
Cheers, guys.
Probably should have explained what I was doing. Laughing
For all high draw stuff I normally use a relay switched by the lighting circuit.
However I'm fitting a voltage display (will hopefully warn me when my reg/reg inevitably dies), so was looking for a switched voltage with the smallest loss, this seems to be the ignition switch, which only drops about 0.2V, compared to the lighting circuit which drops about 0.5-0.7V.
stonesie
PostPosted: 18:09 - 22 Jun 2013    Post subject: Reply with quote
Ah ok, if it's one of These like I have on mine then they use an absolutely tiny amount of power, you should be able to bridge that into just about anything.
Aff
PostPosted: 18:15 - 22 Jun 2013    Post subject: Reply with quote
Nah its one of these.
Not worried about it sapping power, just me being OCD and wanting it to display an accurate voltage. Laughing
The last post was made 13 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 52.75 Kb
