Rear Wheel Removal CG125-ES7
bennett88
PostPosted: 22:34 - 26 Jun 2013    Post subject: Rear Wheel Removal CG125-ES7 Reply with quote
Hi All,
Last week my rear tyre pressure suddenly dropped, (ive got Avon tubeless tyres) so had to push it 3 miles home :/.
I have tried re-inflating but its not keeping the pressure with no obvisous sign of punture.
So my next task it to take the wheel off and get it to a tyre fitter, I have started following my Haynes manual, I have disconnected the torque arm and the rear break rod, no problem.
The next bit I don't understand.
"Slacken off the two wheel spindle drawbolt adjusters, having made a note of their position against the graduations of the fork ends. Pull out the split pin from the castellated wheel spindle nut and remove the nut......the spindle can now be withdran and the wheel lowered from the frame"?
If someone could clarify that would be great.
Many thanks Liam
Dave M
PostPosted: 22:44 - 26 Jun 2013    Post subject: Reply with quote
Slacken off the chain adjusters. Make sure they line up when re installing wheel and adjusting chain slack. Piece o' piss!
Raffles
PostPosted: 22:53 - 26 Jun 2013    Post subject: Reply with quote
If you go onto Youtube, you will find plenty of 'How To..' vids relevant to your needs.
Az
PostPosted: 02:13 - 27 Jun 2013    Post subject: Reply with quote
https://www.youtube.com/watch?v=F4ns9u_JRJ0
That may help
And it basically means that you need to loosen the bolts that you use to readjust-tighten/loosen your chain with and then you take the split pin (google images it if u dont know what it is) from the nut on the long bolt that runs through ur rear wheel (spindle) and wala! you can remove your wheel once you take the spindle out of course Smile
Mark65
PostPosted: 11:36 - 27 Jun 2013    Post subject: Reply with quote
CG tubeless??
bennett88
PostPosted: 21:54 - 02 Jul 2013    Post subject: Reply with quote
It's a tubless tyre with a tube :s. It's a standard Honda cg125-es7.
I've tried all sort but the axle bolt isn't budging, soaked it in penetration spray, got a 12inch torque wrench to try get more leverage nada!
The only thing that's happening is the stand it digging into the tarmac drive, tried turn both end anti-clockwise.
Anymore suggestions?
Many thanks
Liam[/img]
axelfoley
PostPosted: 22:27 - 02 Jul 2013    Post subject: Reply with quote
Stamp/stand on the wrench.
doggone
PostPosted: 22:31 - 02 Jul 2013    Post subject: Reply with quote
You need more leverage by extending your spanner - ideally something like a length of metal tube.
Ideally a socket or ring spanner would be best.
If you round the corners things get worserer.
Take care with spacers, they need to go back exactly as they came out Rolling Eyes
bennett88
PostPosted: 19:34 - 03 Jul 2013    Post subject: Reply with quote
Finally did it, cleaned around the nut, soaked it in penetration spray 2 or 3 times over half and, ring spanner tool wooden mallet, more penetration spray then 12 inch torque wrench and a big foot Very Happy
Islander
PostPosted: 19:44 - 03 Jul 2013    Post subject: Reply with quote
Never ever use a torque wrench for anything other than final tightening of fasteners. For recalcitrant nuts and bolts use a breaker bar and socket.
bennett88
PostPosted: 19:50 - 03 Jul 2013    Post subject: Reply with quote
Even if I set the torque just above what the manual recommend is for tightening it?
Mark65
PostPosted: 20:14 - 03 Jul 2013    Post subject: Reply with quote
Poor torque wrench Crying or Very sad
Islander
PostPosted: 20:48 - 03 Jul 2013    Post subject: Reply with quote
Yes. A torque wrench is a precision instrument it's not a breaker bar.
The last post was made 13 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 77.61 Kb
