Clutch adjustment (urgent)
Supermoto_Fan
PostPosted: 12:08 - 27 Jun 2013    Post subject: Clutch adjustment (urgent) Reply with quote
Levers turned up today so swapped them over, when doing the clutch lever I followed the manual and adjusted the clutch at the lever end to get maximum free play to help me slot it in the lever. I didn't take note of the position of the locknut and adjuster beforehand.
All fitted so go to start her up and nothing at all, check killswitch etc etc, stick it in first and hold in clutch but she still won't roll freely, leading me to believe the clutch isn't fully disengaging? And to start my bike the clutch lever has to be held in. So this is what I'm assuming is the issue
Any ideas on where the lock nut and adjuster should roughly positioned in relation to the cable
SQL
PostPosted: 12:20 - 27 Jun 2013    Post subject: Reply with quote
wind it out as much as you can til it disengages then put in gear and wind it in until in center of the lever
Supermoto_Fan
PostPosted: 12:28 - 27 Jun 2013    Post subject: Reply with quote
I've loosened the adjuster as much as I can get it but still won't move freely in gear with clutch held in.
PostPosted: 12:32 - 27 Jun 2013    Post subject: Reply with quote
Wind the handlebar one in all the way.
On the clutch end, adjust it out until you feel resistance.
Wind it back in 1/4 turn.
Lock it up and adjust freeplay at lever end.
Supermoto_Fan
PostPosted: 12:35 - 27 Jun 2013    Post subject: Reply with quote
By clutch end paddy are you meaning behind the front sprocket cover?
PostPosted: 12:39 - 27 Jun 2013    Post subject: Reply with quote
Indeed.
Supermoto_Fan
PostPosted: 12:50 - 27 Jun 2013    Post subject: Reply with quote
I'm stumped and it's really fucking me off now
SQL
PostPosted: 12:56 - 27 Jun 2013    Post subject: Reply with quote
is there a clutch wsitch (Like the front brake light switch) tried the side stand switch?
weasley
A cold bike will not roll that easily in gear with the clutch in, thanks to viscous drag across the wet clutch even when it is open (certainly it will not roll as easily as if it were in neutral).
Also, whether the clutch is properly adjusted or not, this should not affect the clutch switch for starting as this is usually at the lever, so a fully-pulled lever will activate it and should allow the starter to turn.
Does your new lever actually actuate the clutch switch?
SQL
PostPosted: 13:02 - 27 Jun 2013    Post subject: Reply with quote
also if the clutch is stuck on try bumping it backwards
Supermoto_Fan
PostPosted: 13:03 - 27 Jun 2013    Post subject: Reply with quote
I did think that may be a reason but I wouldn't know, Im going to have to take it off again and see if I can find this switch
Supermoto_Fan
PostPosted: 13:10 - 27 Jun 2013    Post subject: Reply with quote
The clutch switch is covered in gaffa tape (I knew it was like this but figured if it wasnt broken why fix it) I'm gonna strip the tape and go from there.
2 thin wires, join them.
Supermoto_Fan
PostPosted: 13:18 - 27 Jun 2013    Post subject: Reply with quote
To bypass it? Cheers all, I'm just going to follow a simple guide on it on the sv forum. It doesn't help having fingers the size of King Kong when trying to do this
Aff
PostPosted: 13:27 - 27 Jun 2013    Post subject: Reply with quote
Do this, never really understood the point in clutch switches.
Electric Bike Project
PostPosted: 13:34 - 27 Jun 2013    Post subject: Reply with quote
So you are forced to pull clutch in for in gear starts.
Mine doesn't start in gear, Pazzos don't press the switch so I should really bridge mine together Laughing
Aff
PostPosted: 13:38 - 27 Jun 2013    Post subject: Reply with quote
But when is that ever really an issue unless its on a side stand (which has its own cut of switch circuit anyway).
You would literally have to hold down the stater button with no brakes on and not react at all to do any harm.
One or the other, fair enough, but both is just overkill.
PostPosted: 14:03 - 27 Jun 2013    Post subject: Reply with quote
Stalling the R1 in 3rd at lights because you were staring at the RX7 to your left and forgot to shift down...
Embarassed
Supermoto_Fan
PostPosted: 15:07 - 27 Jun 2013    Post subject: Reply with quote
Well I have seemed to have fixed the issue, all is well at the moment. It was indeed the switch. The issue being in settings 1 - 3 the tab on the lever does not connect with the switch. Which isn't really a problem as those settings don't suit me, (5 is best).
After reading I thought it was because id copped out and bought cheapys, hower there are various accounts of this happening with pazzos and ASV levers too!
PostPosted: 15:53 - 27 Jun 2013    Post subject: Reply with quote
But DON'T do this on fuel injected Suzukis. It invokes the neutral fuelling map making the bike run lean and gives you a lower rev-limit.
PostPosted: 16:05 - 27 Jun 2013    Post subject: Reply with quote
Really? Can't say I've seen that before, one to look out for I guess Thumbs Up
weasley
PostPosted: 19:05 - 27 Jun 2013    Post subject: Reply with quote
You're welcome. Mr. Green
Supermoto_Fan
PostPosted: 21:50 - 27 Jun 2013    Post subject: Reply with quote
Karma
The last post was made 13 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.44 - MySQL Queries: 13 - Page Size: 115.04 Kb
