| ts50x0 |
 ts50x0 Spanner Monkey
 Posted: 18:25 - 05 Dec 2004 Post subject: warming up cg125 |
what do people suggest for warming up my cg, i usually warm it up till it will rev ok on half choke then ride it gently for a mile or so.
does this sound ok or do i not really need to bother at all with these?
what do you recon?
cheers
sam  |
| Retro-Man |
 Retro-Man Traffic Copper
 Posted: 18:47 - 05 Dec 2004 Post subject: |
sounds ok to me.
depends on the individual CG really, mine used to start first kick every kick but power would be down if I did not let it warm up for 2-3 minutes before riding.
Retro ____________________ https://domharnessphotography.webs.com |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 18:51 - 05 Dec 2004 Post subject: |
Sounds fine to me too. I've found they splutter and generally sound a bit rough until they're warmed up, but once they're cooking, 10000 rpm sure does sound nice.
Thing is, I've an annoying vibration in my right footpeg at about 7-8k rpm, so of course I have to wind it up to get away from it. You want the choke on for as little time as you can get away with too though, just make sure you're not having to rev it too hard to make it keep running without it.
Mine (as far as it is a CG125) has a tendency to die if you rev it when it's cold, really needing the choke on to start properly at all. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| Retro-Man |
| ts50x0 |
| mchaggis |
 Posted: 22:22 - 05 Dec 2004 Post subject: |
| ts50x0 wrote: | howe do you know what rpm your doing, how do you know if your cg is reving out, mines starts to get really fast(fpor a cg) at about 33mph in 3rd gear then keeps on going untill about 40 when i change to 4th, mine is an old one with numbers around the speedo, my mate said that is to show when each gear is reving out at that speed. is this true? |
Never heard of that one. Doesn't mean it's not true, just I've not heard of it. Basically, you get to know how the engine sounds at different rpm. In any gear but fifth, if it's starting to howl at you it really needs changing up. (Howling on mine starts at about 8k rpm) I personally think changing at arbitrary rpm figures is unneccesary anyway. (Though I would, with a broken tachometer.)
I know whether I'm pushing my bike by how far around the throttle is. There's the last 2k rpm or so for which I have to adjust my hand to twist to, I don't use that range in anything but top, so just don't adjust my grip to twist the extra. ____________________ I must not be a troll...
Mmmm, Guinness
| pipnet11 |
 pipnet11 Brolly Dolly
| mchaggis |
 Posted: 00:49 - 06 Dec 2004 Post subject: |
Good good, just helps ease my mind as to whether my clutch is about to explode.  ____________________ I must not be a troll...
Mmmm, Guinness
| ts50x0 |
The last post was made 21 years, 203 days ago. Instead of replying here, would creating a new thread be more useful? |
