| Nky225 |
 Nky225 L Plate Warrior
| Islander |
 Islander World Chat Champion
| Nky225 |
| Islander |
| Timmeh |
 Timmeh World Chat Champion
 Posted: 14:27 - 01 Jul 2013 Post subject: |
So you've tried basically to go forward with the rear wheel locking solid?
Your tiny little clutch will be fucked, and what's left of the friction material will be floating around in your transmission oil.
If you can't do it yourself, then get someone else to, and get your rear caliper stripped and rebuilt before it happens again.
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:40 - 01 Jul 2013 Post subject: |
When you say that "it didn't work", was the engine revving without making you go anywhere? Or did the revs die off until it stalled?
Can you hear/feel it engaging into gear?
If you get the rear wheel off the ground, does it turn at all when the engine is running? Viscous coupling should put something through to the rear wheel. ____________________ Biking is 1/20th as dangerous as horse riding.
| Nky225 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:13 - 01 Jul 2013 Post subject: |
| Nky225 wrote: | i had notice last week when i cleaned the chain and had the back end on a stand, that when i put it into 2nd with the clutch lever in there was movement/drive which indicates not a full disengagement am i correct? |
That's normal with a wet clutch. The oil between the plates creates some drag and you get a little drive, enough to turn the wheel if it's off the ground.
If you can blag a stand and get the wheel up, I'd suggest that you see if you have any drive at all, and whether engaging the clutch has any effect. ____________________ Biking is 1/20th as dangerous as horse riding.
| Nky225 |
| lihp |
 lihp World Chat Champion
| Sload |
 Sload World Chat Champion
The last post was made 12 years, 279 days ago. Instead of replying here, would creating a new thread be more useful? |
