gs500 fork seal help
dransy
PostPosted: 19:33 - 02 Jul 2013    Post subject: gs500 fork seal help Reply with quote
How the fudge do you get the bottom allen key bolt out ?
Ive tried the broom handle trick to stop it turning inside but it doesnt work! Sad
Bezzer
PostPosted: 19:44 - 02 Jul 2013    Post subject: Reply with quote
The broom handle works only if you're lucky as it only grips the top end of the damper tube you need a pointed length of bar that will reach down the inside of the tube and grip in the lower hole.
or you can buy the Suzuki tool for stupid money. I bought one donkeys years ago as it also fits GS, Bandits etc, it's 3/8th square drive and you stick a couple of feet of extensions on it to reach the hole bottom.
https://i561.photobucket.com/albums/ss60/mickcbr1100/tools/ForkTool.jpg
dransy
PostPosted: 19:53 - 02 Jul 2013    Post subject: Reply with quote
managed to get lucky Very Happy
https://i1342.photobucket.com/albums/o764/dransy87/IMAG0191_zpsbf86a1a6.jpg
First time doing it,i didnt realise you actually had to twat the broom handle in Very Happy
dransy
PostPosted: 20:33 - 02 Jul 2013    Post subject: Reply with quote
When putting it back together do I have to do an air gap test ?
dransy
PostPosted: 21:02 - 02 Jul 2013    Post subject: Reply with quote
Bezzer
PostPosted: 22:37 - 02 Jul 2013    Post subject: Reply with quote
It's always better to set the airgap than rely on a measurement of oil, that way you always make sure both legs are the same. Doesn't matter as much when the legs are fully stripped and dry but it is a quick accurate way of doing it if you use a syringe and can make a difference when you just change the oil.
The last post was made 13 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 49.04 Kb
