| ian505050 |
 ian505050 Traffic Copper
 Posted: 21:35 - 02 Jul 2013 Post subject: What happens when you connect battery terminals wrong |
What happens when you connect battery terminals the wrong way when trying to jump start a car.
The Car is a 2006 1.6 Petrol Focus
1.)Car will not start due to dead battery and the only noise that can be heard is a clicking due to lack of power in the battery.
2.)Someone comes along and tries to jump start the car using jump leads from another car that is running but connects them up the wrong way for 15 seconds causing the cables to heat up.
3.)The car now now shows a red light and the display reads 'engine system fault'
4.) The car now no longer attempts to start (no clicking noise) and will only show the above error message.
What will be damaged? The AA guy says fried ECU or blown a big fuse.
The car still has all its lights on the dash and the displays all work and it recognizes when the bonnet is open or a door is open ect.... but does not make any sort of noise to even attempt to start.
I have taken my car to a local side street mechanic that we know who has a diagnostic machine to check for faults.
My question is on a scale of 1 to 10 how worry should i be and what parts may need replacing? Is the ECU the worst case scenario?
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%203/IMAG3416_zps1e86d78a.jpg |
| Slacker24seve... |
 Slacker24seve... World Chat Champion
 Posted: 21:44 - 02 Jul 2013 Post subject: Re: What happens when you connect battery terminals wrong |
| ian505050 wrote: | What happens when you connect battery terminals the wrong way when trying to jump start a car.
If the AA guy says that, check the fuses. If they're intact, then worry. ____________________ Triumph Daytona 675 track bike + girlfriend's Honda Hornet 600
Banger rallies are ace |
| BakesBeans |
 BakesBeans Spanner Monkey
| ian505050 |
| Nexus Icon |
| ThoughtContro... |
 ThoughtContro... World Chat Champion
| Boxing |
 Boxing World Chat Champion
 Posted: 03:59 - 03 Jul 2013 Post subject: |
Will the person who put the jump leads on the wrong way around be contributing towards the repair bill?
Also in the event of a flat battery, surely if its a manual it'd be a lot easier to just ask someone to give you a push and you can bump it? Drive it for an hour and if the battery is good it should charge up. |
| FirebladeRuss |
 FirebladeRuss Spanner Monkey
| Hetzer |
 Hetzer Super Spammer
| Rogerborg |
 Rogerborg nimbA
| The Artist |
 The Artist Super Spammer
| goto10 |
 goto10 World Chat Champion
| Clutchy |
 Clutchy World Chat Champion
 Posted: 11:30 - 03 Jul 2013 Post subject: |
As said, disconnect battery for an hour, new battery and then post back results! ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| uberkron |
 uberkron Crazy Courier
| uberkron |
| Nb |
 Nb World Chat Champion
| Sako |
 Sako World Chat Champion
| FirebladeRuss |
 Posted: 08:52 - 05 Jul 2013 Post subject: |
Honestly, my money is on the battery being definetly goosed first and foremost, with the diode/rectifiers on the alternator likely to be damaged a close second.
There's always a risk it may be the ECU, but that is worst case. It's a bit like asking online why your car has a bit of white goo on the oil filler cap even though the car runs fine. 90% of people will be telling you the head gasket's gone, whereas often it's a simple as the car only does 2 mile journeys and it's condensation build up.
Start with trying cheap/free options first.
Spurious dash messages like "engine systems fault" could mean anything, not specifically that the ECU is cooked.
https://www.fordownersclub.com/forums/topic/33911-2006-focus-engine-system-fault/
First step is to borrow a working battery and see what the car does.
I'm suprised the battery didn't do something spectacular when connected the wrong way, as they often do. ____________________ Twitter is for people who can't STFU even when they're by themselves
| Hetzer |
| Nb |
| treeno |
 treeno Crazy Courier
There is a gap of 319 days between these two posts... |
| crazy Legs |
 crazy Legs L Plate Warrior
| EazyDuz |
 EazyDuz World Chat Champion
The last post was made 12 years, 177 days ago. Instead of replying here, would creating a new thread be more useful? |
