Oring Chain
SQL
PostPosted: 20:27 - 03 Jul 2013    Post subject: Oring Chain Reply with quote
How do I put on the masterlink its too tight. I am puzzled.
Quote Me Happy
PostPosted: 20:32 - 03 Jul 2013    Post subject: Reply with quote
Errr, push it on?
More details needed - what type of link? What's too tight, the chain or the actual fitting of the link?
SQL
PostPosted: 20:34 - 03 Jul 2013    Post subject: Reply with quote
RK o ring chain with 428 master link,it is just impossible to push it on :/ I cant compress it over the ridges for the clip
SQL
PostPosted: 20:35 - 03 Jul 2013    Post subject: Reply with quote
fitting the plate before the clip its the plate that is tight
Quote Me Happy
PostPosted: 20:43 - 03 Jul 2013    Post subject: Reply with quote
What have you tried using to push it on? I've always used a chain tool but you could always use a C clamp or something similar to push it on.
SQL
PostPosted: 20:53 - 03 Jul 2013    Post subject: Reply with quote
yes tried that, I can't compress the orings enough by hand
jimspeed
PostPosted: 21:14 - 03 Jul 2013    Post subject: Reply with quote
mole grips or something, or maybe a good pair of pliers?
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Fizzer Thou
PostPosted: 00:44 - 04 Jul 2013    Post subject: Reply with quote
https://preview.mandp.co.uk/p/533054/chain-riveting-and-breaking-tool
This is the type of tool that I use for installing soft links and spring clip links.They can be used to press the inner link over the pins until there is sufficient space for the spring clip to be installed.The same procedure is used for a soft link,except that I prise the outer link out a bit after I have splayed out the soft pins.This then allows the rivetted link to move more freely.
Always have a 'Plan B'
Mark65
PostPosted: 11:27 - 04 Jul 2013    Post subject: Reply with quote
When I did mine on my old YBR and after putting grease in the link I compessed the side plate on with a pair of needle nosed pliers as the orings are not compressed like the rest of the chain. Then I cold put the split pin on.
The last post was made 13 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 62.46 Kb
