Changing an oil pressure sensor.
PostPosted: 21:18 - 03 Jul 2013    Post subject: Changing an oil pressure sensor. Reply with quote
Had a whiff of burning oil.
https://i104.photobucket.com/albums/m174/howlingterror_2006/oil017_zpse51b74f9.jpg
Traced it back to the sensor, and I suspect the connector that fits into the sensor unit has failed and allows oil back out (I did check the tightness of the unit first, it was tight enough).
Ordered a new sensor and connector (£20).
Simple job but I have questions. How do I disconnect the wire and what is this red thing that I can slide out?
https://i104.photobucket.com/albums/m174/howlingterror_2006/oil011_zps1899915f.jpg
https://i104.photobucket.com/albums/m174/howlingterror_2006/oil016_zps3277fa90.jpg
https://i104.photobucket.com/albums/m174/howlingterror_2006/oil015_zps82fe83ac.jpg
stonesie
PostPosted: 21:56 - 03 Jul 2013    Post subject: Reply with quote
That red thing is the lock to keep the wiring connector in it's plastic housing, the seal on it is to keep water out and not oil in so the sensor itself has failed.
How to disconnect it? You will figure it out but personally I would NOT change the connector Thumbs Up
PostPosted: 00:56 - 04 Jul 2013    Post subject: Reply with quote
Yep unscrew sensor, screw in new sensor, plug in wire with old connector. No need to change that.
The last post was made 13 years, 105 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 37.68 Kb
