| johnsta0492 |
 johnsta0492 L Plate Warrior
| P.addy |
 P.addy Red Rocket
 Posted: 13:16 - 04 Jul 2013 Post subject: |
What is the issue first before you go twisting stuff  |
| pits |
 pits World Chat Champion
 Posted: 13:43 - 04 Jul 2013 Post subject: |
Yeah it's in the dedicated workshop section for fixing bikes and technical problems like this.  ____________________ Stinkwheel: You have no right to free speech
00:33:00 Blau Zedong: the CB400 is my favourite road bike |
| Lord Percy |
 Lord Percy World Chat Champion
| johnsta0492 |
| P.addy |
 P.addy Red Rocket
| Lord Percy |
 Posted: 08:33 - 05 Jul 2013 Post subject: |
Mine used to do that too. It was because I'd replaced the carb with a non-OEM Chinese replica, I took it apart and found half the internal parts were slightly different to the actual specified requirement.
If it's bogging down at high revs, it's not getting enough fuel and I think there are a few possible causes:
If it's the original carb then you can rule out anything being the wrong size, and instead I would suggest that it just needs cleaning thoroughly, or the floats (number 24 in the image) and parts connected to that area may be damaged.
However if the carb is a replica or replacement, your best bet is to take it off, take it apart and check the codes stamped on the main jet (parts 16 and 20 in the diagram) to see if they match up with the specific information in the Haynes manual. For example, my main jet was supposed to be something like 102.5Z, but the jet in my new carb had a totally different code stamped on it so I knew it was wrong.
If you can't be arsed pulling it apart and doing all that checking, a new EN/GN 125 carb is quite cheap compared to most others.
| Paddy Blake |
| Lord Percy |
| callum94 |
 callum94 Nova Slayer
The last post was made 12 years, 362 days ago. Instead of replying here, would creating a new thread be more useful? |
