running in new front sprocket?
speedyspeedyb...
PostPosted: 14:46 - 04 Jul 2013    Post subject: running in new front sprocket? Reply with quote
Just upgraded my front sprocket from a 15 tooth to a 17 tooth. Just wanted to know if I need to run the thing in? If so I'd guess I just have to be a bit more gentle with my gear changes for a couple hundred mile. Ta.
Country lane warrior
Lexmoto lsm125
PostPosted: 14:47 - 04 Jul 2013    Post subject: Reply with quote
Not necessary.
Islander
PostPosted: 14:48 - 04 Jul 2013    Post subject: Reply with quote
Nope. If it's fitted correctly then just crack on.
Timmeh
PostPosted: 14:49 - 04 Jul 2013    Post subject: Reply with quote
And if it's not fitted correctly, you'll know within the first ten minutes.
The only thing we would suggest is giving it a good seeing to and then checking that the nut is still properly tight afterwards.
speedyspeedyb...
PostPosted: 16:22 - 04 Jul 2013    Post subject: Reply with quote
Test riding the beast now. Wish me luck.
Lexmoto lsm125
Conzar
PostPosted: 16:26 - 04 Jul 2013    Post subject: Reply with quote
No..power wheelie away!
Oh..Lexmoto 125..
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
speedyspeedyb...
PostPosted: 18:04 - 04 Jul 2013    Post subject: Reply with quote
Just done a couple miles and I'm quite happy. It basically feels like my gears have shifted (1st feels like 2nd, 2nd like 3rd). Where I used to change to 5th at 60mph I'm now changing at 65mph. I have lost a bit of low end power but if I get in the habit of changing down more often it should be fine.
Conzar: I'll have you know I have a whole 9.5bhp! Rolling Eyes
Lexmoto lsm125
Timmeh
PostPosted: 19:19 - 04 Jul 2013    Post subject: Reply with quote
That's cos you've changed the final ratio.
More teeth on the front - higher top speed, less acceleration.
speedyspeedyb...
PostPosted: 19:52 - 04 Jul 2013    Post subject: Reply with quote
Yeah I was expecting that lol.
Only problem now is the beast needs more power to back up the new gear ratio. I'm changing into 5th and its just going flat. I'll see how things go but might try a 16 tooth one soon.
Lexmoto lsm125
Walloper
PostPosted: 21:28 - 04 Jul 2013    Post subject: Reply with quote
PM sickpup he may have powerbands to fit your engine. Thumbs Up
speedyspeedyb...
PostPosted: 22:34 - 04 Jul 2013    Post subject: Reply with quote
Walloper: this is probably gonna sound stupid but what are power bands? I'd presumed they were just certain area of the revs which you get the most power ie 2 strokes being the top couple thousand Confused
Lexmoto lsm125
bladerunner
PostPosted: 00:14 - 05 Jul 2013    Post subject: Reply with quote
at least with the taller gearing you can make use of that tail wind or down hill speed advantage!
dublinclontar...
PostPosted: 00:16 - 05 Jul 2013    Post subject: Reply with quote
If you're on a 125 4stroke then there is absolutely no point in attempting to trade acceleration for top speed.
A 125 simple doesn't have enough guts to push you terribly fast, at least a 4 stroke, I've no experience of a two stroker.
I'd recommend you just use the standard sprocket, it's already the right size to reach the top speed of that bike.
PostPosted: 00:30 - 05 Jul 2013    Post subject: Reply with quote
Two stroke 125 wins.
speedyspeedyb...
PostPosted: 04:11 - 05 Jul 2013    Post subject: Reply with quote
dublinclontarf: I went for a bigger sprocket because my route to work is 10 mile of dual carriage way, which meant I had to pin the poor thing to keep with traffic. This wouldn't be a problem but on my beautifully crafted Chinese machine flat out for this long results in oil coming out my air box (egr valves are a great idea Neutral ). So I'm not aiming for more top end, just trying to be kind to my little engine and take some of the strain off it.
Lexmoto lsm125
Boxing
PostPosted: 04:40 - 05 Jul 2013    Post subject: Reply with quote
Until it blows up or needs a top end rebuild. Laughing
SQL
PostPosted: 08:55 - 05 Jul 2013    Post subject: Reply with quote
thats because you went +2 you only need to go +1 on the front and -1 on the back.
speedyspeedyb...
PostPosted: 09:28 - 05 Jul 2013    Post subject: Reply with quote
In case anyone cared, I've just purchased a 16tooth sprocket. I'll let you know how it goes when it arrives.
The beauty of chink bikes? Dirt cheap parts Very Happy
Lexmoto lsm125
Hetzer
PostPosted: 10:14 - 05 Jul 2013    Post subject: Reply with quote
That's because they're made out of cheese. Cheap cheese.
skatefreak
PostPosted: 12:28 - 05 Jul 2013    Post subject: Reply with quote
In which case you're doing it wrong...
They are still full of win!
-Jvr
The last post was made 13 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 104.73 Kb
