Radiator leaking....i'm gonna cry
Shinigami
PostPosted: 18:35 - 04 Jul 2013    Post subject: Radiator leaking....i'm gonna cry Reply with quote
So my rad has sprung a leak on the way home from work today, no idea why or how, rad was already bent so might be the eventual result of that.
Is there any way to repair it or am I looking at a new rad? cheapest i've found is £125 Sad not good when i'm utterly skint due to having to move house soon and most ikely be unemployed for a short while
SQL
PostPosted: 18:46 - 04 Jul 2013    Post subject: Reply with quote
radweld
Shinigami
PostPosted: 18:49 - 04 Jul 2013    Post subject: Reply with quote
does that stuff work well? or is it very temporary? apparently putting black pepper in works aswell temporarily?
doggone
PostPosted: 18:54 - 04 Jul 2013    Post subject: Reply with quote
Or egg white, but it would be a lot better to get radweld or if it's an obvious leak can you solder it up?
Radweld will only give you a few weeks most likely, although you can do it repeatedly it's best considered temporary while you find an replacement.
matto
PostPosted: 19:01 - 04 Jul 2013    Post subject: Reply with quote
JB weld!
www.ebay.co.uk/like/350482999838
Had a pinhole leak on the rad of an old bike, this fixed it and I believe it's still fixed now, just stuck a blob over where the leak was.
Mark65
PostPosted: 19:13 - 04 Jul 2013    Post subject: Reply with quote
https://www.granvilleoil.com/product_info.php?prod_id=54
Used it years ago and it worked.
Timmeh
PostPosted: 19:20 - 04 Jul 2013    Post subject: Reply with quote
radweld is ok, brazing or soldering would be the permanent fix.
SQL
used it in 100's of fucked cars with no ill effects.
charlie74
PostPosted: 19:23 - 04 Jul 2013    Post subject: Reply with quote
alot will depend on where the leak is, if its in the core, much harder, if its in the frame or external pipe connections, more options are about
the one rad additive i would recommend is K-SEAL, or possibly the new radweld plus
Efes123
PostPosted: 19:36 - 04 Jul 2013    Post subject: Reply with quote
Just get it re-cored. I got a Jag rad (which is rather large) done for about 60 odd quid. It's a damn site cheaper than getting even a second hand one.
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
bridgedino
PostPosted: 20:00 - 04 Jul 2013    Post subject: Reply with quote
This worked for my badly leaking rad, saved me spending...
Bought a tube of 'metal putty' . Worked a blob of it into the rad grills using one of those wee wallpaper seam rollers. Let it set over-night
Job done. Was a nice cheap option that worked for me after the rad weld kept failing after a few days use
Shinigami
PostPosted: 20:34 - 04 Jul 2013    Post subject: Reply with quote
not sure exactly where it's coming from, it's the left lower somewhere, not sure i'd trust radweld for anything in the long run by the sounds of it a new rad would be best :/
this is the leak when i stopped when i got home, it was coming out way quicker when i stopped at the lights earlier though
Clicky for video
https://i4.photobucket.com/albums/y109/Stevie_J/th_20130704_172334_zpsa89e2c36.jpg
SQL
PostPosted: 20:41 - 04 Jul 2013    Post subject: Reply with quote
If you can afford to buy a new raditor then do it, if not solder/radweld etc...
I thought you couldn't get new one
charlie74
PostPosted: 20:51 - 04 Jul 2013    Post subject: Reply with quote
that aint a leak, its a drip
chuck some k seal in it and it will hold for a long time, certainly long enough for you to not worry about finding the money for a new rad
i used k-seal as a temp fix on a weaping headgasket on a toyota 2.4 diesel, and 2 yrs later it was still ticking along
if your still keen to get a new rad, ask around at your local motor factors if they know of any radiator recore specialists, that may work out much cheaper, and you will get a much better quality core at the end of the day than a cheap import
Shinigami
PostPosted: 20:59 - 04 Jul 2013    Post subject: Reply with quote
cool i'll get some sealer in it then, do halfrauds sell it as not sure where else round here would
It does drip a lot more than that when hotter though, lost 2 litres of coolant riding home from it
TheManWithThe...
PostPosted: 21:13 - 04 Jul 2013    Post subject: Reply with quote
I had a leak about the size of yours; not massive, but still noticed the damp patch on the radiator and it dripping when i parked up.
I stuck some radweld in there back in march and thats done the job and is still holding strong, so i'd recommend it.
MBK Nitro 50, Sold. Kawasaki ER-5, Honda ST1100
"Anyone can jump a motorcycle! The trouble begins when you try to land it..."
Walloper
PostPosted: 21:26 - 04 Jul 2013    Post subject: Reply with quote
I would get Barrs leaks into the radiator. It works MUCH MUCH better than Radweld.
If possible flush the system with the Barrs Flush.
I've used Barrs leaks for years and it has never failed.
You need a new radiator as the one in there is worn.
There are much cheaper than a new engine. Razz
Shinigami
PostPosted: 21:31 - 04 Jul 2013    Post subject: Reply with quote
was thinking a new one was probably the wise way to go, mainly due to this one being bent and worn (it's done 80k miles)
the leak is much worse than it looks here but rad had already cooled a bit by this point like i said, lost 2 litres over a maximum of 30 minutes..
will try the bars stuff from halford tomorrow first, if it doesn't work looks like the credit card will have to come out of hibernation Sad
charlie74
PostPosted: 21:32 - 04 Jul 2013    Post subject: Reply with quote
halfrauds dont usually sell k-seal but worth asking.. but yeah get bars leak, instead of radweld
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_208015_langId_-1_categoryId_255217
PostPosted: 23:06 - 04 Jul 2013    Post subject: Reply with quote
My car is 3? 4? years into a Radweld bodge. Just do it.
stuartt
PostPosted: 23:13 - 04 Jul 2013    Post subject: Reply with quote
i had a hole in my busa's radiator about 2 years ago , i stuck a bottle of k seal in it & its been fine since Very Happy
Shinigami
PostPosted: 16:16 - 06 Jul 2013    Post subject: Reply with quote
put a shot of radweld in this morning, was still leaking while the engine was idling (ran it for 25 mins) let it cool down again, just been out for a short 10 mile ride and no sign of leaking now Thumbs Up no idea how long it will hold up but will give me time to sort out finances a bit more and source a cheaper rad
Islander
PostPosted: 18:09 - 06 Jul 2013    Post subject: Reply with quote
Keep your eye open on the Hornet's Nest - they crop up there from time to time. Thumbs Up
Shinigami
PostPosted: 20:14 - 06 Jul 2013    Post subject: Reply with quote
there's some on ebay from china for £80, no idea on quality with them being from china but I reckon the people selling for £125 in the uk on there are selling the same ones they've imported themselves
charlie74
PostPosted: 00:14 - 07 Jul 2013    Post subject: Reply with quote
manufacturing quality of the chinese ones wont be that bad( its not that hard to make a rad) but the quality of the metals etc used.... who knows
add in the risk of damage by the carefull shipping handlers...
up to you, but i would prefer a uk seller, even if it was a chink part, at least you would be on uk soil and covered properly by sellers regs
i guess the real question is how much longer do you intend to keep the bike, i would expect a chink rad to last at least 3-4 yrs if not repainted before fitting
The last post was made 13 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 123.52 Kb
