remote reservoir suspension
ocatoro
PostPosted: 13:05 - 06 Jul 2013    Post subject: remote reservoir suspension Reply with quote
afternoon... I thought i'd have a look under my reservoirs thismorning to see if i could work out preload adjustment on them etc....
i've got valves under there, like on a tyre.. does air go in? or some sort of fluid? i pushed the pin and i got a little hiss for 1 second and that was it. so i presume theyre empty of whatever goes in them...
CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
Current - None Sad but shed project H100 (first bike Smile )
Past - ER5, '93 ZZR600, '92 CB400 SF, ZZR600 (again), yellow Monster 620, Blackbird - black Monster 620ie - '96 ZZR600
lihp
PostPosted: 16:02 - 06 Jul 2013    Post subject: Reply with quote
preload is on the spring tension.
That valve is for refilling the shock with nitrogen. It will be empty now if you let it out, and you'll need to take it to a specialist to have it refilled
ocatoro
PostPosted: 16:37 - 06 Jul 2013    Post subject: Reply with quote
Well if that's the case, it needed filling anyway. I literally touched it for a second. If i managed to empty it all in that time the pressure would have been incredible... It was lower pressure than a bicycle tyre valve.
Will go get it filled and adjusted etc...
Enduro Numpty
PostPosted: 19:37 - 06 Jul 2013    Post subject: Reply with quote
There is very little volume in these reservoirs. That's why it emptied so quickly.
Billing
PostPosted: 20:30 - 06 Jul 2013    Post subject: Reply with quote
It might be possible that it's to do with preload adjustment, my NC23 has Schrader valves on top of the forks
ocatoro
PostPosted: 21:01 - 06 Jul 2013    Post subject: Reply with quote
been out for a wander. it doesn't feel any different to before. i'm down swansea on thursday, anyone know if M&P does nitrogen?
The last post was made 13 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.63 - MySQL Queries: 13 - Page Size: 52.51 Kb
