brake pistons / pads
s1h
PostPosted: 20:10 - 07 Jul 2013    Post subject: brake pistons / pads Reply with quote
Ive been a twat I attempted to change my brake pads and have got in a mess. I got the old ones out then pressed the brake lever and the piston came up. I can't get it back in its not fully out but how do I push it back in it just won't budge
Quote Me Happy
PostPosted: 20:18 - 07 Jul 2013    Post subject: Reply with quote
First of all don't go too near the lever for now and don't panic.
Take a toothbrush and clean up the piston you can see using some brake fluid. Then push the piston back in - you may need something to help you - got C clamp or similar? Put the old pad between the piston and the clamp though. Failing that put one of the old pads back in to protect the piston and use a screwdriver to lever it back in.
Then pump the piston out a bit more and clean up the crud again and push back in. This should get it moving more freely and give you space to get the pads in.
PostPosted: 20:21 - 07 Jul 2013    Post subject: Reply with quote
As above. But also wash off all traces of brake fluid from any painted part of the bike (and from the tyres) as soon as possible.
Wobbling Dog
PostPosted: 20:37 - 07 Jul 2013    Post subject: Reply with quote
if you can get one in, hacksaw the piston til the pads fit or cut the brake pipe to relieve the pressure to push the piston back in then join the pipe back up with a biro and jubilee clips-bleed,nah,fuk it, spongy brakes have more feel.
Dave M
PostPosted: 20:47 - 07 Jul 2013    Post subject: Reply with quote
+1 on this Shocked
s1h
PostPosted: 20:58 - 07 Jul 2013    Post subject: Reply with quote
Good news a c clamp did the job applying pressure on one off the old pads.
However what looks like some metal clip or something has now come out any idea what it is and how it fits back in? Does this hold the pads in at the bottom?
Starting to wish I hadn't attempted this now
Quote Me Happy
PostPosted: 07:14 - 08 Jul 2013    Post subject: Reply with quote
Did you work out how it fits back in? It will sit in the calliper against the sides of the pads.
What bike is it?
s1h
PostPosted: 19:21 - 08 Jul 2013    Post subject: Reply with quote
What bike is it?
No chap, struggling here. It's cb600f honda
This is the bit I'm talking about
Ripp3rCrust
PostPosted: 19:45 - 08 Jul 2013    Post subject: Reply with quote
Looks like one of the anti-rattle clips. If you take the pads out of the caliper again and look at the bottom of the caliper where the pads are seated, there should be a slightly recessed area that this piece should nicely slot into.
Current: '05 CBR600F - Previous: '01 GSF600S Bandit, '06 XR125
Aff
PostPosted: 19:47 - 08 Jul 2013    Post subject: Reply with quote
IIRC the hornet rear brake pads have 1 pad retaining pin.
So the pad spring should just sit in the hole at the top of the calliper (domed side facing out).
The pads should have 2 bits sticking out with on the top, which when pivoted into the calliper, touch the 2 "feet" of the spring and holds them tight.
Electric Bike Project
s1h
PostPosted: 19:54 - 08 Jul 2013    Post subject: Reply with quote
Cheers. Yeah it doesn't seem to nicely slot in and the pads don't seem to just slot into it. Sure it's something simple dont really want to admit defeat though.
Maybe ill pick up a Haynes, might have some pictures.
Aff
PostPosted: 19:56 - 08 Jul 2013    Post subject: Reply with quote
https://www.carlsalter.com/pdfs/Honda_CB600F_Hornet_%2798_Service_Manual.pdf
s1h
PostPosted: 13:41 - 09 Jul 2013    Post subject: Reply with quote
Hello people. Finally getting somewhere. Had originally thought the pads had to clip into that spring. Now I've worked out they don't I've cracked it. Well sort of. I've put it all back together but now the rear brake is sticking. It's ok going forward but really sticking if I push the bike backwards.
Any ideas what have I done wrong, something done up to tight. I was thinking maybe I'd pumped the lever too many times as the piston is quite far out?
Islander
PostPosted: 15:46 - 09 Jul 2013    Post subject: Reply with quote
Is the caliper moving freely on its slider pins?
s1h
PostPosted: 15:50 - 09 Jul 2013    Post subject: Reply with quote
It wasn't but it is now Very Happy
The last post was made 13 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 86.71 Kb
