Manual for GPZ500
Fallen Angel
Franny the Nanny
PostPosted: 14:22 - 06 Dec 2004    Post subject: Manual for GPZ500 Reply with quote
Would anyone happen to have a link to an on-line manual for a GPZ500?
Cheers
Fran Thumbs Up Karma Thumbs Up
I have an asshole tolerance level of -10 Twisted Evil
Mr. Green Dance! Mr. Green www.cliqueyclanmcc.co.uk Mr. Green Dance! Mr. Green
www.bebo.com/fallenangelfran
instigator
PostPosted: 15:52 - 06 Dec 2004    Post subject: Reply with quote
Whilst you're at it, one for an ER-5 as well....
niff5855
Sausage Boy
PostPosted: 16:15 - 06 Dec 2004    Post subject: Reply with quote
bollox I forgot - I've got a Haynes manual too. Embarassed
Its probably tucked away in my mums attic in Wales anyway though.
Live fast - die....erm...well...old !!!
Fallen Angel
Franny the Nanny
PostPosted: 17:14 - 06 Dec 2004    Post subject: Reply with quote
No worries Leigh, I'll get a hold of one somewhere mate - you've done enough so far!!! Mr. Green
Fran
niff5855
Sausage Boy
PostPosted: 17:27 - 06 Dec 2004    Post subject: Reply with quote
I've also got a spare kidney if anyones looking ??
hehehe Rolling Eyes
Fallen Angel
Franny the Nanny
PostPosted: 17:29 - 06 Dec 2004    Post subject: Reply with quote
lol Laughing
LustyLew
PostPosted: 18:15 - 06 Dec 2004    Post subject: Reply with quote
What do you want to know? My manual covers the Gpz and ER5. I could scan in pages if you're looking for some thing specific?
Let me know Smile
Fallen Angel
Franny the Nanny
PostPosted: 10:27 - 07 Dec 2004    Post subject: Reply with quote
Unfortunately I need to know everything 'cause the thing's just not starting at all - there's a little bit of power going through the engine, as the lights / indicators, etc. work, but it won't start, not even a peep. It also won't even go into second gear. So I reckon we've got to go through quite a lot of trouble-shooting things to figure out what's wrong with it. ;?
LustyLew
PostPosted: 10:35 - 07 Dec 2004    Post subject: Reply with quote
Right, well if it's anything like the ER5 it wont go into 2nd unless the bike is moving, strange I know.
Off the top of my head, I dont know how many pages the hwole manual, but I'll have a scoot around Smile
map
Mr Calendar
PostPosted: 10:44 - 07 Dec 2004    Post subject: Reply with quote
Fallen Angel wrote:
...there's a little bit of power going through the engine, as the lights / indicators, etc. work, but it won't start, not even a peep...
If it's been stood for a while make sure you charge the battery (An optimate is your new best friend). Otherwise try and jump it from another car battery or starter pack. This is from recent experience of a bike not starting and fixed by charging battery, new battery now on order.
Also if being stood check out the carb(s) as the petrol may have turned to gunk inside them (try carb cleaner squirted through the air box!).
<edit>make sure it's in neutral as well to start Rolling Eyes Very Happy </edit>
HTH Smile
Fallen Angel
Franny the Nanny
PostPosted: 10:48 - 07 Dec 2004    Post subject: Reply with quote
Will do Thumbs Up
It was - ya cheeky monkey!!! Wink
PostPosted: 11:28 - 07 Dec 2004    Post subject: Reply with quote
Couple of things with the GPZ.
Firstly, as already mentioned, the GPZ is a bugger for getting water in the petrol tank. Fine until you use reserve when it gets into the carbs (petrol floats on water, and the reserve takes fuel from the very bottom of the tank). Make sure you have enough petrol in so that you do not need to use reserve.
If there is water in the carbs then there is a drain screw on the bottom of each one.
The GPZ fuel tap does not have a prime position. Think both normal and reserve are vacuum operated, so the engine needs to be running (or cranking over reasonably quickly) for fuel to flow out of the tank to the carbs. Also it needs to be doing this for quite a while for the carbs to fill up (likely that having been sat any in the carbs has evaporated).
In summary, put a gallon or 2 of fresh petrol into the bike. Put the fuel tap to "ON". Drain the fuel out of the carbs. Put a fresh fully charged battery on to it (or use some jump leads with a car battery, although be careful as the GPZ battery terminals are quite close to the frame and you do not want to catch the +ve lead on to that). Then try again.
PostPosted: 22:45 - 07 Dec 2004    Post subject: Reply with quote
The clymer manual for the EX500 (the american name for the GPZ) is better than the haynes GPZ500s one. Clearer and more detailed IMO.
Full Bananas
PostPosted: 09:59 - 08 Dec 2004    Post subject: Reply with quote
Check the kill switch.
"Work is the curse of the drinking class."
The last post was made 21 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 91.01 Kb
