1997 DTR Spluttering At 8-9K RPMs
Boxing
PostPosted: 13:29 - 09 Jul 2013    Post subject: 1997 DTR Spluttering At 8-9K RPMs Reply with quote
Hi, as title says my DT is spluttering at 8-9K and the top speed is miles away from 70MPH. It's only doing 50MPH. 60 If I'm really pinning it.
It's supposed to do close to 70MPH.
Things I've done to it:
Arrow Topend rebuild
Arrow Checked the Reed's they're fine
Arrow Adjusted the airscrew according to the Haynes Manual.
Arrow Sprockets and chain changed for D.I.D ones.
Arrow Checked the carbs main jet #240
Running out of ideas now. The compression is fine, starts fine but the top speed and everything is way out. Sad
madcookie38
PostPosted: 02:50 - 12 Jul 2013    Post subject: Re: 1997 DTR Spluttering At 8-9K RPMs Reply with quote
Have you checked the power valve to see if its fully open ? also is the front pipe standerd or not ? if yes to both of these, i would check the needle pin in the carb slide to make shaw its in the right place as may be starved of fuel, hope this helps
Boxing
PostPosted: 04:41 - 12 Jul 2013    Post subject: Re: 1997 DTR Spluttering At 8-9K RPMs Reply with quote
Has a DEP expanny and powervalve is set to where it should be. Sad
I'm going to rip the filter out tomorrow and test it. Might be a dirty filter.
The last post was made 12 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 36.01 Kb
