Honda mtx 125 no spark
Adam2188
PostPosted: 20:23 - 21 Jul 2013    Post subject: Honda mtx 125 no spark Reply with quote
Hey ppls am new rider and also first time on bike chat but in need of a bit of help. Does anyone know of any problems with ignition components on Honda mtx 125 1985? Has been temperamental with a weak spark since having it. Now has no spark. Have put brand new coil pack, lead and plug on. What next??
misscrabstick
PostPosted: 20:44 - 21 Jul 2013    Post subject: Reply with quote
You really need to find a wiring diagram, but anyway, so what's left in the system that could cause this? poor wiring and or connections, faulty cut out switch on handle bar, faulty ignition switch, faulty cdi/ignition control unit, pickup assy ( probably on the flywheel generator somewhere), faulty windings in the generator, I am being a bit general as I am not familiar with this bike, really you need to get testing with a multimeter or a scope in a logical manner using the wiring diagrams, throwing bits at it until it works can be expensive.
PostPosted: 20:48 - 21 Jul 2013    Post subject: Reply with quote
I assume you have tried a new spark plug...
Adam2188
PostPosted: 11:50 - 22 Jul 2013    Post subject: Reply with quote
Have a recently purchased a owners haynes manual which has wiring diagrams and already have a multimeter. doesnt help that i have a flat battery. Think i overcharged it after having gone flat from leaving ignition on and fried it. will get a new batt and do some testing, jus needed a point in right directio. cheers. ps changed coil due to being faulty anyway and plug because when bike was running it was overoiling
webhead
PostPosted: 14:06 - 24 Jul 2013    Post subject: Reply with quote
hi dude weak sparky ok, clean up the wires specally earth wire, check block connector near head light for green poop if there clean it with switch cleaning.
secondly take off lefthand tank fairing here you will see your electrics , coming up the frame is the generator wires make sure there all clean and connected, check all the connectors for grean poop , if yes clean them , when done make sure battery is full charged, then see if you have spark , if yes cool , if not , then take off lefhand generator cover and make sure the flywheel is tight if its loose then woodruff key is buggered and your crank probably shagged mtx125,s love doing theis , but if loose take off bolt take off flywheel and check to see if key is ok, if all this is ok , by a multimeter and , check generator wires to ground ,put multimeter wire to ground casing anying earth on bike, then check each wire if it shoes up with continuity as in connects shows a reading then your generator coil is pooped, your need a new 1 ,but if all that's ok , then the next thing is the cdi unit.
Timmeh
PostPosted: 14:11 - 24 Jul 2013    Post subject: Reply with quote
do you have a brother called findley?
The last post was made 13 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 57.12 Kb
