Gluing Footpeg Rubber.
johnsmith222
PostPosted: 23:36 - 22 Jul 2013    Post subject: Gluing Footpeg Rubber. Reply with quote
Hi guys,
Unfortunately the footpeg rubber came off my footpeg on the ZZR yesterday. I managed to save the rubber and it is in good condition.
My only problem is what glue I should use to put it back on?
I'm actually quite para that it comes off again so I could run 3 pieces f lockwire round the footpeg to hold it on as well as the glue.
Thanks for any help. Thumbs Up
Ariel Badger
PostPosted: 23:42 - 22 Jul 2013    Post subject: Reply with quote
Try hairspray, it is old school but works on twist-grips.
Nexus Icon
PostPosted: 23:51 - 22 Jul 2013    Post subject: Reply with quote
Does it sit on top of the metal or sleeve it like a hand grip does?
If it's the former you'll be best off with an epoxy like Araldite. They do a fast cure version which works extremely well.
If it's a sleeve type then, as Ariel suggested, hairspray will probably work fine.
Greetings from Shitsville!
Ariel Badger
PostPosted: 00:03 - 23 Jul 2013    Post subject: Reply with quote
If it sits on top I would suggest a glue formulated for shoe repair as it will have a degree of flexibility.
Timmeh
PostPosted: 00:14 - 23 Jul 2013    Post subject: Reply with quote
Any glue that forms a flexible bond will do, UHU immediately springs to mind. I wouldn't use superglue or epoxy as they tend to be quite brittle.
johnsmith222
PostPosted: 00:18 - 23 Jul 2013    Post subject: Reply with quote
Thanks for the help guys. Fortunately my mum had some UHU type glue. I wouldn't have normally trusted this but I have decided to lockwire the rubber on using 3 different pieces of lockwire. I think I'll do the same for the other side to help keep that one on.
It was the type that just sits on top of the peg rather than going right round it otherwise I would have tried something with hairspray or similar.
Thanks again. Thumbs Up
Nexus Icon
PostPosted: 13:21 - 23 Jul 2013    Post subject: Reply with quote
I'm sure anything mentioned above will do but I'm curious as to why you'd need flexibility. I'm pretty sure that the piece of steel, which makes up the supporting body of the footpeg, isn't flexing anywhere so why would the rubber need to? It'll squash a bit, within itself, but it's not going to bend.
garth
PostPosted: 13:53 - 23 Jul 2013    Post subject: Reply with quote
I have a bit of a lockwiring fetish. It gets addictive. The twirly bit with the special pliars. Oof.
Islander
PostPosted: 14:33 - 23 Jul 2013    Post subject: Reply with quote
The rubber can move/flex and hence so can the joint between the rubber and the metal support. Contact type adhesives are the way to go here. Thumbs Up
Richy CB1000
PostPosted: 17:16 - 23 Jul 2013    Post subject: Reply with quote
You could try the black silicone sealant stuff, (like the bath sealant they say it's different stuff but I think it's the same), those lovely fella's at Halfords stock it, a small tube for few quid. I've used it on shoes, temp water pump gasket on the car (never did need fixing again!) under the sink to stop a small water leak and various other things, works for me as it sticks and stays flexible.
janner_10
PostPosted: 18:19 - 23 Jul 2013    Post subject: Reply with quote
I would try some contact adhesive. Works pretty well on rubber metal combo.
PostPosted: 18:33 - 23 Jul 2013    Post subject: Reply with quote
Gorilla glue. It's a moisture-activated polyurethane glue and the most versatile stuff I've found to date. £7 for a good sized pot.
The last post was made 13 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 71.92 Kb
