what could it be?!
j.silvs
PostPosted: 08:54 - 24 Jul 2013    Post subject: what could it be?! Reply with quote
So my gsxr like to loose revs and conk out anytime the engine gets above 100degrees.
I have also noticed that even when idle my lights dim slightly and flicker. If I have my indicators on they both dim and get brighter when each other is on.
Have changed the oil, spark plugs and the rad has coolant.
Could this be a power issue? - changed the rec a fee months ago and the bike starts on the button. Guessing there's something wrong with the draw as it seems to conk out when the fan comes on?
Any ideas?
Aff
PostPosted: 08:57 - 24 Jul 2013    Post subject: Reply with quote
Have you tested by forcing the fan to come on?
The fan isn't usually a massive draw, mine drops my voltage by .4, what condition is your battery in?
Also check what your getting from the stator and regrec.
Electric Bike Project
j.silvs
PostPosted: 09:00 - 24 Jul 2013    Post subject: Reply with quote
Nope haven't forced the fan on. I think the fan thing may be more of a co-incidence
How would I do the check on stator / rec?
Aff
PostPosted: 09:01 - 24 Jul 2013    Post subject: Reply with quote
Got a multimeter?
Supermoto_Fan
PostPosted: 09:05 - 24 Jul 2013    Post subject: Reply with quote
Was this happening before you serviced it mate?
j.silvs
PostPosted: 10:12 - 24 Jul 2013    Post subject: Reply with quote
No multimeter but I am sure I can get one,
No this happened before the service which is why I thought I better have a go!
PostPosted: 10:23 - 24 Jul 2013    Post subject: Reply with quote
Get the bike running and check voltage across the battery at off, idle and 5k rpm.
j.silvs
PostPosted: 11:33 - 24 Jul 2013    Post subject: Reply with quote
Will do that and report back.
Thanks all
Aff
PostPosted: 11:57 - 24 Jul 2013    Post subject: Reply with quote
Also bridge the fan on to see what the drop is like, if it has a huge effect it could be faulty.
j.silvs
PostPosted: 10:24 - 25 Jul 2013    Post subject: Reply with quote
Just another thought on this.
Its not always happening when the fan is on now.
Could it be worth just increasing the idle speed as I have noticed that when I hold the revs slightly it wont cut out.
At the moment the bike idles anywhere between 600k and 800k - I think this is wrong anyway so may increase the idle to around 1000k - 1200k
What do you think?
Timmeh
PostPosted: 10:26 - 25 Jul 2013    Post subject: Reply with quote
I'd say somewhere between 1000-1250 is about right for a 600.
j.silvs
PostPosted: 10:29 - 25 Jul 2013    Post subject: Reply with quote
So it could just be a case of adjusting the idle?
I have noticed its due on the service intervals
Timmeh
PostPosted: 14:04 - 25 Jul 2013    Post subject: Reply with quote
The only way to found out if it works is to do it.
You won't wreck anything by messing with the idle. However do let it warm up first.
Supermoto_Fan
PostPosted: 14:40 - 25 Jul 2013    Post subject: Reply with quote
600 sound way too low, I thought the average was 1000 - 1200
The last post was made 13 years, 72 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 77.25 Kb
