| shuffy1989 |
 shuffy1989 Derestricted Danger
| Efes123 |
 Efes123 World Chat Champion
 Posted: 11:54 - 23 Jul 2013 Post subject: |
Inb4 sell it and buy something more sensible
Serious answer. When you say "full power" what do you mean? It does sound carb related, and sounds like the idle speed is set too low, needs a small turn on the screw. Have you tried spraying some quick start, or something similarly combustible around the air box intake? If it revs higher when you do this, then you have a loose connection. ____________________ Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD |
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| Efes123 |
| shuffy1989 |
| UnknownStuntm... |
| Efes123 |
 Posted: 12:16 - 23 Jul 2013 Post subject: |
That's the problem with these bikes, too many people f**k about with them trying to get more power and end up screwing the bike up .
I do hope you have a license to ride it
Anything done to de-restrict it by it's nature will have an affect on the fuel mix, including idling settings. Check the rubber collars where the air box and the carb meet. Are they in good condition, and are they tight? I presume the "jetted in stuff with a power valve" means that the jet sizes have been modified, but not quite sure what the power valve bit is.
EDIT: Damn, need to type faster, although you answer is more eloquent  ____________________ Honda Goldwing GL 1000 Current love
| shuffy1989 |
| shuffy1989 |
| UnknownStuntm... |
 Posted: 12:20 - 23 Jul 2013 Post subject: |
Look at this, compare images etc:
https://www.nsr125.com/derestrict.htm
If I were you, I'd half trust the jetting to be 'working' so don't fiddle with that. As Efes123 said, check the rubbers and small pipes all around the place, make sure there's nothing 'missing'. |
| Efes123 |
 Posted: 12:25 - 23 Jul 2013 Post subject: |
It's unlikely you'll be able to get it back to 'normal'. I seem to remember reading somewhere that de-restricting requires drilling into the exhaust and doing 'something', sorry, memory is a bit vague.
Just start with checking the connections. Too much or too little air will have an effect. If you try putting the original; box back on, you'll then have to change the jets back, as US says, try not to change too much at any one time. And try the simple things first. ____________________ Honda Goldwing GL 1000 Current love
| shuffy1989 |
| Efes123 |
 Posted: 12:35 - 23 Jul 2013 Post subject: |
One will be a drain pipe (should be fairly small diameter) at the bottom of the carb (it to drain excess fuel from floats), the other, more normal size, is the breather. There should be an oil and a fuel pipe in. ____________________ Honda Goldwing GL 1000 Current love
| shuffy1989 |
| Clutchy |
 Clutchy World Chat Champion
 Posted: 12:42 - 23 Jul 2013 Post subject: |
Some of these bikes are modded to run pre-mix (pretty pointless, usually when the pump fails) and they do away with the 2t reservoir, does yours have one? Have you topped it up?
Does sound more like a low idle? Can you rev through the whole rev range? ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| Efes123 |
| Efes123 |
| shuffy1989 |
| Efes123 |
 Posted: 08:14 - 24 Jul 2013 Post subject: |
TBH, this is a bit difficult as have no idea of what's been modified I found this which might be useful to you:
It sounds like you have two problems: 1) the idle is too low, and 2) the high revving.
1 should be a simple adjustment by turning the idle screw in slight increments, should be done when engine is warm.
2 could be several things. It might be worth while whipping the carb off and opening it up to see if there's any gunk inside, and the floats are working as they should. A fairly simple job, just make sure you don't damage the gasket, or you'll have to buy a repair kit. They don't cost a fortune, but it'll mean the bike's off the road till you fit it. You'll also need to go over the air box with a fine tooth comb to check for cracks, and the state of the air filters. ____________________ Honda Goldwing GL 1000 Current love
| UnknownStuntm... |
 Posted: 09:15 - 24 Jul 2013 Post subject: |
| Efes123 |
| TheSmiler |
 TheSmiler World Chat Champion
 Posted: 09:35 - 24 Jul 2013 Post subject: |
Meh I'm no help with bikes but to me something sounds like sticking throttle or air leak.
| Efes123 wrote: |
Guilty as charged ociffer.
Do you know whether the Korn from that site THE Korn? |
Considering BCF is a site spawned from the original NSR chat forum. I believe it is  ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
A2 completed 23/07/15 Ready for the Golden Crisp Packet |
| raesewell |
 raesewell Traffic Copper
The last post was made 13 years, 88 days ago. Instead of replying here, would creating a new thread be more useful? |
